07-16-2019 05:43 AM
I need to form a VPN Tunnel from A side to B side. B Side use 10.50.x.x as internal range which A side uses as well. is there any way we can find a solution?
07-16-2019 05:47 AM
Hi there,
Surely every device at one site does not require connectivity to every device at the other site?
In the likely event that each site offers a small subset of services which need to be accessible, then I suggest you use static NAT to hide the 'real' 10.50.x.x IP addresses and then advertise the NAT pool subnet to the other site.
cheers,
Seb.
07-16-2019 05:52 AM
To add to what @Seb Rupik mentioned, here is a guide on how to deal with overlapping subnets on the ASA:
07-16-2019 08:27 AM
Thank you both. The problem over here is Site A is accessing resources from Site B
Site A uses 10.50.50.0/24 as an example and advertised out through out Site A's networks
Site B also uses the same range
so what can be done to for site A to access Site B. We used to use Public IP's but Site B does not have public available
07-16-2019 08:56 AM
hello
Form what I understand from the question now is
10.50.50.0/24 -----A(1.1.1.1)============B(2.2.2.2)------------10.50.50.0/24
earlier you had an available public Ip address on both sites A and B and you were able to NAT 10.50.50.0/24 ( on side A) to X ip address and 10.50.50.0/24 ( on side B) to Y ip address. Now, B doesn't have Y and so you cant use it anymore. Is this is the scenario you are trying to implement?
you can use a local IP( y ip address) on side B, NAT all 10.50.50.0/24 behind site B to that and add it to the Crypto ACL .
earlier the Crypto ACL was X to Y and Y to X . now this can be changed to X to y.
of course you would need to allow access for y wherever Y had access earlier.
Is this the topology? if not, could you please share the topology, even a simple example would do to make sure we understand what you are trying to achieve.
The 2nd thing which comes to my mind is Site B is totally routed to site A and doesn't have any Public IP and you want to route all traffic from Site B to Site A and make sure Site A can access all resources behind B.
Shikha Grover
07-16-2019 09:26 AM
Yes the above is correct, however in Site A, they also use 10.50.50.0/24 and company policy is generally to use crypto tunnel to Public IP and not Private IP to Site B. Site B has a public range (Ex: 7.7.7.0/24) but cant use it for this purpose
So is there any other way? Am I making it clear?
07-16-2019 10:01 AM
Hello
I am sorry however you would need to compromise on one of the things:-
You either can use a LOCAL IP ( going against your company policy) or make arrangements for a Public IP ( which isn't available for now)
Shikha Grover
Please rate the answers that are helpful
07-16-2019 01:46 PM
Clear, thank you for quick reply
