ACS Remote agent problem
tornido9999
I have problem with acs remote agent authentication for VPN connection, i want to delete the agent and point it to another server i click on this remote agent and then delete and apply it gave me the below error:
This Agent is being used for NT Authentication, this must be re-configured before it can be deleted
What should i do to delete it ??
i also want to ssh to device what is the default username and password ?
thanksssssssssssss
Eugene Khabarov
Level 7
Level 7
what is the version of ACS do you use?
For 4.2/4.1 Look at
External Users Database ->
Database Configuration ->
Windows Database ->
External User Database Configuration ->
Windows User Database Configuration ->
Windows Remote Agent Selection
And remove agents here.
___
HTH. Please rate this post if it was helpful. If this solves your problem, please mark this post as "Correct Answer"
5 Replies 5
Eugene Khabarov
Level 7
Level 7
For 4.2/4.1 Look at
Windows Database ->
___
Thanksssssssssssss
I have another problem, i can access GUI of ACS 4.2.1 Appliance (Not windows based), i want to access the ssh of this device i dont have username and password can i create or set this through GUI interface ???
thanksssss  again
Hi!
Appliance administrator can be added only througth CLI.
___
Hi, is there any solution i can do to solve this problem, i dont have CLI password ?
Yes, it is possible.
Here is password recovery procedure described:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_solution_engine/4.2/installation/guide/solution_engine/admap.html#wp1048831
http://www.cisco.com/en/US/products/sw/secursw/ps5338/products_password_recovery09186a00801ece5f.shtml
___
