Anyconnect doesn't work across BVI interface
VitaliiN
Hello Cisco community.
I have a strange issue when using BVI on an ASA 5506 X. Here is a picture of the current network. I have two interfaces on BVI 1 with one network and 2 interfaces on BVI 100 with another network.
Servers connected to BVI 1 interfaces reach each other, management interfaces of both servers are accesible too from each server. The strange things begins when i try to access outside through anyconnect client - I can reach both management interfaces, but only HV1 interface is accesible through anyconnect vpn. The BVI's configs are the same, i have proper firewall rules for each interface, and same-security-trafic is enabled for intranet interfaces.
Could anyone can help me to handle this?
Thanks in advance
6 Replies 6
can I see ASA config ?
Sure, take a look the attachment.
your Config is clear correct but
let test with packet tracer
packet tracer input outside tcp 172.16.113.50 12345 <HV1 or HV2 IP> 80 detail
please share output of this
VitaliiN
Just to be sure I set up a tiny httpd on 1180 port and checked that it is accessible from the 192.168.113.x network.
Here is the packet tracer output:
packet-tracer input outside tcp 172.16.113.50 12345 192.168.113.18 1180
Phase: 1
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (HV1,outside) source static NAT_HV1_LAN NAT_HV1_LAN destination static VPN_USERS VPN_USERS
Additional Information:
NAT divert to egress interface HV1
Untranslate 192.168.113.18/1180 to 192.168.113.18/1180
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: HV1
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule, Drop-location: frame 0x0000560ee785c4bb flow (NA)/NA
It seems that I need to create allowing acl rule for outside, right?
access-list global_mpc extended permit ip object NAT_HV1_LAN any4<<- why this ACL ?
This ACL uses only with service policy rules for traffic inspection.
