AnyConnect problem with installation
aaltamirano
I need your expirience with this problem.
when i tried to install AnyConnect_VPN_Client_2.3 until end i recieved this messege
Service 'Cisco AnyConnect VPN Agent' (vpnagent) failed to start. Verify that you have sufficient privileges to start system services.
I tried to install AnyConnec with normal installation and administrator profile and i recieved the same messege.
Somebody can help me please. Maybe you have in the past the same problem.
npokhriy
What is the operating system you are using?
Try to upgrade the latest anyconnect version on your machine.
Naresh
Jigar Dave
Level 3
Level 3
hope below steps help you.
1. uninstall existing client set up
2. try to access external ip (outside interface of firewall) from your browser
3. it will ask you to install anyconnect vpn client software, install that.
4. when you run the anyconnect vpn first time, make sure that you logged in your system with admin priviledge username
5. right click on anyconnect icon, run as administrator.
I think this should work.
let us know
JD...
