AnyConnect - Secure Gateway problem
brian.stivala
I have configured anyconnect on ASA firewall but I'm unable to connect, I can access the web page SSL VPN, but when I try to connect via the anyconnect vpn software downloaded from the ASA itself I am experiencing the attached error.
I've checked the event viewer on windows 8 and found the the following.
Using default preferences. Some settings (e.g. certificate matching) may not function as expected if a local profile is expected to be used. Verify that the selected host is in the server list section of the profile and that the profile is configured on the secure gateway.
Can I get some help on this one, I'm sure that this is something to do woth the configuration of anyconnect.
Brian Stivala
Michael Muenz
Level 5
Level 5
Please add the link of the SSL VPN to your trusted sites in IE
Michael Please rate all helpful posts
Try new version of SSL VPN. That might work.
Jawad
malshbou
it seems that you need to push the XML profile from the ASA with specific attributes.
let's know the anyconnect version you use
Mashal
------------------ Mashal Shboul
