ASA 5520 Remote VPN and NAT
hashknife
I have a situation that may be solvable via NAT, but I'm not sure. I'm not as familiar with
the ASA 5520 8.0 as I'd like to be.
Preface:
ASA 5520 with IOS version 8.0 (can't upgrade because of RAM)
VPN accessed on a public address
VPN is setup and so that when clients connect, they're assigned a private IP address
from a pool range: 192.168.253.0/248.
Using Cisco AnyConnect VPN client
This works accessing all remote publicly addressed networks.
Client side cannot access remote privately addressed network (192.168.252.0/24).
Client side treats remote private address as a local route and will not go through the VPN.
I need to access 5 remote devices in this remote private address space via the VPN.
The privately addressed network sits on the same switch as the public networks and they all use
the same inside gateway, the the ASA 5520's Inside interface.
I'm unfamiliar with syntax of the NAT and ACL commands on the ASA 5520.
Questions:
If I use an unassigned public address space, can I NAT using
these public addresses to this private network on the ASA 5520 side?
If so, what commands/ subcommands and caveats do I need to know?
Will I need to set up a separate VPN policy on the ASA 5520?
If, so what would I need to setup?
I've tried to find a good command reference, but can't find what I want.
Do you all have any links I could try?
Thank you all very much for your time.
Bryant C Mothershed
(just an old cowboy that wound up in IT...)
hashknife
Please disregard this question. I was completely off base with my thinking. It turned out to be a simple problem with the the remote access split tunnel ACL.
Sorry for the inconvenience, folks.
Bryant C Mothershed
