ASA 9.0.2 - LDAP, MS AD, ldap-base-dn CN problem
Matus Kozak
Level 4
Level 4
i have configured LDAP authentication on ASA for VPN users. In MS AD I have a group named "VPN_Users" but it's CN.
ldap-base-dn CN=VPN_Users,OU=users,DC=company,DC=local
The path identified in AD shows:
DN:        CN=VPN_Users,OU=users,DC=company,DC=local
I want allow only users which are in mentioned group. But it does not work. It seems that "CN=VPN_Users" is not a accepted like group but it is.
Any idea? or experience? Its IOS bug or what.
thanks.
Jatin Katyal
HI Matus,
This is what you need.
Configuration for restricting access to a particular windows group on AD
ldap attribute-map LDAP-MAP
  map-name  memberOf IETF-Radius-Class
  map-value memberOf CN=VPN_Users,OU=users,DC=company,DC=local <Group Policy Name>
! ---Group-Policy-Name should be group-policy that you configured on ASA---
aaa-server LDAP-AD protocol ldap
aaa-server LDAP-AD host
server-port 389
ldap-base-dn DC=company,DC=local
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-dn
ldap-login-password
server-type microsoft
ldap-attribute-map LDAP-MAP
group-policy internal
group-policy attributes
vpn-simultaneous-logins 3
vpn-tunnel-protocol IPSec l2tp-ipsec ...
address-pools value
group-policy noaccess internal
group-policy noaccess attributes
vpn-simultaneous-logins 1
address-pools none
tunnel-group type remote-access
tunnel-group general-attributes
authentication-server-group LDAP-AD
default-group-policy noaccess
Just in case, it doesn't work for you. Get the following information:
Turn on the "debug ldap 255" on the ASA and Connect with a user account who belongs to VPN-Users group
1.] Show run ldap
2.] Show run aaa-server
3.] show run tunnel-group
4.] Show run group-policy
OR
You can provide the SH RUN from the ASA.
Jatin Katyal
- Do rate helpful posts
~Jatin
7 Replies 7
Jatin Katyal
HI Matus,
server-port 389
ldap-scope subtree
ldap-login-dn
ldap-login-password
address-pools value
address-pools none
1.] Show run ldap
OR
Jatin Katyal
~Jatin
Hi Jatin,
thanks for reply and help. I tried your config before I posted the question here, but I forgot group-policy "noaccess".
In your solution in GP noaccess is "vpn-simultaneous-logins 1". there hould be "0" i think.
I will test it deeper later today.
matus
Hi Matus,
yes, it should be 0. sorry for the typo.
because we don't want to assign any session to the end user.
Jatin Katyal
- Do rate helpful posts -
~Jatin
Were you able to restrict the access in your last test? did you come across any other issue?
Jatin Katyal
~Jatin
I'm waiting for MS AD administrator to test. Because a lot of  AD groups etc. And I want to test how it will work when users will move to another group in AD tree, how AD path will be changed etc.
Matus K.
Hello Jatin,
so finaly I was able to restrict the access to mentioned group and users which are not in the group are not able to connect. So it looks good. I have no other issues for now. Thanks.
Matus
It would be good if you mark this thread stands resolved so that other's can take benefits out of it.
Jatin Katyal
~Jatin
