Cisco 2511 problem
mohammed hashim
hi all
I purchased a lab similar to INE CCIE R&S lab
however, I am facing a small problem on cisco 2511 terminal server.
the router is working and I am able to access it via console as well as telnet.
on 2511 asynch interfaces (two interfaces 1-8 and 9-16) all the network devices is connected through these.
but the issue is these two interfaces stop working suddenly and I lose the connection to the devices !!
everything is working fine if I manualy connect to the console !
if I restart 2511, then it start working OK, and after while same issue happens again.
is there any thing to do here ?
this is my configuration on 2511
AS2511#show running-config
Building configuration...
Current configuration : 886 bytes
version 12.2
hostname AS2511
logging queue-limit 100
enable password cisco
ip subnet-zero
ip host R6 2006 172.22.1.1
ip host R5 2005 172.22.1.1
ip host R4 2004 172.22.1.1
ip host R3 2003 172.22.1.1
ip host R2 2002 172.22.1.1
ip host R1 2001 172.22.1.1
ip host SW1 2009 172.22.1.1
ip host SW2 2010 172.22.1.1
ip host SW3 2011 172.22.1.1
ip host SW4 2012 172.22.1.1
interface Loopback0
no ip address
interface Ethernet0
ip address 172.22.1.1 255.255.0.0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
no ip http server
ip classless
line con 0
password cisco
login
line 1 16
exec-timeout 0 0
flush-at-activation
login
no exec
transport input all
line aux 0
line vty 0 4
password cisco
login
end
AS2511#
Peter Koltl
Level 7
Level 7
clear line
command can help
