Cisco 881 Rourer LAN to LAN ipsec tunnel Problem
fhit111111
Dear All
Can Cisco 881 Router use the LAN Interfaces  to establish an ipsec  tunnel ?
I do not want to use the WAN interface  to establish an ipsec  tunnel
Sheraz.Salim
yes i did in the past. you have to create a vlan x, than create a svi and bind that vlan x to the interface ethernetX. when it will come to crypto map you have to bind the crypto map to the vlan x
interface vlan x
 ip adress x.x.x.x x.x.x.x
 crypto map x
please do not forget to rate.
balaji.bandi
Depends on how your Ethernet interface exposed to external side.
https://www.cisco.com/c/en/us/td/docs/routers/access/800/software/configuration/guide/SCG800Guide/SCG800_Guide_BookMap_chapter_01010.html
BB
Sheraz.Salim
interface vlan x
 crypto map x
Thank you for answering my question.
