2286
Peter Handke
Beginner
cisco asa 5510 and zyxel ZyWALL 35 ipsec s2s disconnect problem
I have asa and zyxel connected  via ipsec s2s. The problem is with disconnecting. Traffic origin from Zyxel site to Asa site. After tunnel hang up we have to turn on tunnel by hand on Zyxel site.  It happens few times per day. Quality of Internet connection is ok. I changed few settings but without success. On cisco site i have ca 30 another tunnel s2s  to different countries and all are ok. On Zyxel site i have  1 extra vpn. It works ok. Below my config and logs. I'll be very grateful for help
regards
Peter
asa 5510 8.2
zyxel :
Model ZyWALL 35
Bootbase Version V1.07 | 03/23/2004
Firmware Version V4.04(WZ.8) | 02/11/2010
cisco conf :
IKE Peer: 6.6.6.194
Type   : L2L             Role   : responder
Rekey   : no             State   : MM_ACTIVE
Encrypt : 3des           Hash   : SHA
Auth   : preshared       Lifetime: 86400
crypto ipsec transform-set tunel esp-3des esp-sha-hmac
crypto map outside_map 67 match address acl-67-xxx
crypto map outside_map 67 set pfs
crypto map outside_map 67 set peer 6.6.6.194
crypto map outside_map 67 set transform-set tunel
crypto map outside_map 67 set security-association lifetime seconds 86400
p1:
psk
Negotiation Mode main
Encryption Algorithm 3des
Authentication Algorithm sha1
SA Life Time (Seconds) 86400
Key Group dh2
Enable Multiple Proposals
p2:
active
nailed-up
Encapsulation Mode tunnel
Active Protocol esp
Perfect Forward Secrecy (PFS) dh2
cisco errors when tunnel hang up:
Session disconnected. Session Type: IKE, Duration: 0h:00m:06s, Bytes
xmt: 0, Bytes rcv: 0, Reason: User Requested
Session disconnected. Session Type: IKE, Duration: 0h:00m:05s, Bytes
zyxel errors:
2012-08-06 13:39:39 Rule [2n-vpn-172-2-1-0] delete successfully
   IKE
2012-08-06 13:39:39 The SPI and sequence number are : 0xA8A434B6 /
372       IKE
2012-08-06 13:39:39 Rule [2n-vpn-172-2-1-0] idle time out, disconnect 7.7.7.7.194 6.6.6.182 IPSEC
372 7.7.7.7.194 6.6.6.182 IPSEC
2012-08-06 13:39:32 Firewall session time out, sent TCP RST
192.168.2.43:54151 172.27.104.207:139 TCP RST
2012-08-06 13:39:28 Send:[HASH][DEL] 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:28 The cookie pair is : 0xF51036F015A5CDC0 / 0xF650FB62C6E4F1CE 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:28 Recv:[HASH][NOTFY:ERR_SPI ] 6.6.6.182
7.7.7.7.194 IKE
2012-08-06 13:39:28 The cookie pair is : 0xF51036F015A5CDC0 / 0xF650FB62C6E4F1CE 6.6.6.182 7.7.7.7.194 IKE
2012-08-06 13:39:28 Firewall session time out, sent TCP RST
192.168.2.43:54150 172.27.104.207:445 TCP RST
2012-08-06 13:39:22 Rule [2n-vpn-172-2-1-0] Tunnel built successfully 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:22 The cookie pair is : 0xF51036F015A5CDC0 / 0xF650FB62C6E4F1CE 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:22 Send:[HASH] 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:22 Recv:[HASH][SA][NONCE][KE][ID][ID] 6.6.6.182
7.7.7.7.194 IKE
2012-08-06 13:39:22 The cookie pair is : 0xF51036F015A5CDC0 / 0xF650FB62C6E4F1CE 6.6.6.182 7.7.7.7.194 IKE
2012-08-06 13:39:22 Send:[HASH][SA][NONCE][KE][ID][ID] 7.7.7.7.194
6.6.6.182 IKE
2012-08-06 13:39:22 Phase 1 IKE SA process done 7.7.7.7.194
6.6.6.182 IKE
2012-08-06 13:39:22 Recv:[ID][HASH] 6.6.6.182 7.7.7.7.194 IKE
2012-08-06 13:39:22 Send:[ID][HASH] 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:22 Recv:[KE][NONCE][VID][VID][VID][VID 6.6.6.182
7.7.7.7.194 IKE
2012-08-06 13:39:22 SMTP fail (Trying to send another mail now, please wait.)
2012-08-06 13:39:22 IKE Negotiation is in process 7.7.7.7.194
6.6.6.182 IKE
2012-08-06 13:39:22 Send:[KE][NONCE] 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:22 Recv:[SA][VID] 6.6.6.182 7.7.7.7.194 IKE
2012-08-06 13:39:21 Send:[SA][VID][VID] 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:21 The cookie pair is : 0xF51036F015A5CDC0 /
0x0000000000000000 7.7.7.7.194 6.6.6.182 IKE
2012-08-06 13:39:21 Send Main Mode request to [6.6.6.182]
2012-08-06 13:39:21 Rule [VPN-Polen-Krakau] Sending IKE request
0 REPLIES 0
Content for Community-Ad
