04-28-2014 04:31 AM
Solved! Go to Solution.
04-28-2014 05:28 AM
Go to Configuration > Device Management > Advanced > SSL Settings. there you should be able to choose the inside interface and associate a secondary certificate to that interface only.
You will have had to create (or import from a CA) a new certificate already. (Configuration > Device Management > Identity Certificates > Add)
04-28-2014 05:28 AM
04-28-2014 07:38 AM
Thank you!
