VPN
Cisco CyberSecurity
Labels
Hello, I recently installed Secure Client 5.1.2.42 on Win11 23H2 (HU language). Setup was OK, I received no error.After starting the client, the application didn't start, the appl. log shows me the this:The name of the modul, which occured the proble...
TamasMate by Level 1
  • 2 Views
  • 0 replies
Hi, I have one issue with IPSec tunnel Lan-to-Lan between ASA 5525x (v9.8) and ASA FPR 2110 (v9.16). My Tunnel is up but ping between each client was not successful. Both peer status sh cry isakmp sa in "MM_ACTIVE".I ran packet-tracer icmp between pe...
El Rondo by Level 1
  • 128 Views
  • 7 replies
I have a DMVPN network with 4331 hub routers. Our HQ in Memphis has a hub on AT&T, and another on Lumen. Our New York hub is also a Lumen connection. All are 500Mb up/down. We have about 35 spokes around the US that peer to all 3 routers. BGP is the ...
Hello everyone!Tunnel1 - destination tunnelTunnel2 - source tunnelsource_IP - ip of the source router (branch router)dest_IP - ip of the destination router (main router) I am getting anti-replay errors, logs are collected on the main router*Apr 15 04...
Hello,When configuring SSL VPN, the default encryption type is "ssl server-version tlsv1.2 dtlsv1.2", which only shows up with a "show run all". In that output, I can also see that "ssl cipher tlsv1.2 medium" and "ssl cipher dtlsv1.2 medium" are disp...
Hello, any help appreciated.I am having issues when trying to assign a different group policy to a user where the group policy contains a different client profile (XML) to the one used to connect in the first instance. This is what I am trying to do....
 Due to Covid-19 we are working from home by connecting to office VPN.  Since yesterday entire office was asked to WFH and since then we got some intermittent disconnection issues.  Issue - from home connecting to Cisco VPN is ok, but once connected ...
I searched the internet and this forum and have found nothing for my issue and hoping I can get some help here. I am using AnyConnect and can successfully connect to multiple customers, but am experiencing an issue with one customer when using RDC, b...
rklump42 by Level 1
  • 2714 Views
  • 3 replies
Hello,I have a problem with Cisco AnyConnect VPN but it's related to a single computer only. Everything is working just fine as long as I am doing regular things. However when I increase network load (copying files through RDP, browsing through googl...
Mi1anovic by Level 1
  • 477 Views
  • 19 replies
  • 1 Helpful votes
Sometimes I'm using our VPN near the end of the 24-hour limit, and it warns me that it's about to run out. Then it cuts the connection suddenly and interrupts my work. There is no option to continue. It would be much better if there were a button to ...
spudboy by Level 1
  • 1991 Views
  • 6 replies
  • 5 Helpful votes
