DMVPN Spoke does not receive EIGRP routes for other Spokes
mrguitar
Level 4
Level 4
Trying to ping the Spoke 2 LAN from Spoke 1 fails (and vice versa) because there is no route in the routing table.  Putting static routes in the spokes works, however, so it's not a connectivity problem.
Here's the Hub config:
interface Tunnel2550
bandwidth 3000
ip vrf forwarding UMMA01
ip address 172.31.255.1 255.255.255.224
no ip redirects
ip mtu 1380
no ip next-hop-self eigrp 2550
ip nhrp authentication XXXX
  ip nhrp map multicast dynamic
ip nhrp network-id 2550
ip nhrp holdtime 600
no ip split-horizon eigrp 2550
tunnel source GigabitEthernet0/0
tunnel mode gre multipoint
tunnel key 2550
tunnel protection ipsec profile ENCRYPTEDGRE
Spoke 1:
bandwidth 3000
ip address 172.31.255.2 255.255.255.224
no ip redirects
ip mtu 1380
ip nhrp map multicast 1.1.1.1
ip nhrp map 172.31.255.1 1.1.1.1
ip nhrp nhs 172.31.255.1
tunnel key 2550
Spoke 2:
bandwidth 3000
ip address 172.31.255.3 255.255.255.224
no ip redirects
ip mtu 1380
tunnel source FastEthernet0/0
tunnel key 2550
Here's the IP NHRP table from spoke 1:
NEXUMMA01#sh ip nhrp
172.31.255.1/32 via 172.31.255.1
   Tunnel2550 created 03:54:40, never expire
   Type: static, Flags: used
   NBMA address: 1.1.1.1
172.31.255.2/32 via 172.31.255.2
   Tunnel2550 created 00:00:10, expire 00:09:49
   Type: dynamic, Flags: router unique local
   NBMA address: 2.2.2.2
    (no-socket)
172.31.255.3/32 via 172.31.255.3
   Tunnel2550 created 00:00:10, expire 00:09:48
   Type: dynamic, Flags: router used
   NBMA address: 3.3.3.3
Here's ping results from Spoke 1 to Spoke 2 tunnel:
NEXUMMA01#ping 172.31.255.3
Sending 5, 100-byte ICMP Echos to 172.31.255.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/20/20 ms
NEXUMMA01#
Here's the routing table for the Spoke 1 LAN:
      192.168.255.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.255.0/24 is directly connected, GigabitEthernet0/1.2550
L        192.168.255.1/32 is directly connected, GigabitEthernet0/1.2550
Routing table for Spoke 2 LAN:
      192.168.254.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.254.0/24 is directly connected, Vlan2550
L        192.168.254.1/32 is directly connected, Vlan2550
Routing table on Hub:
D     192.168.254.0/24 [90/2135808] via 172.31.255.3, 00:15:35, Tunnel2550
D     192.168.255.0/24 [90/2135808] via 172.31.255.2, 00:15:35, Tunnel2550
It's just not propagating the routes to the spokes for some reason.  Please assist.  Wondering if it has anything to do with the hub tunnel using a VRF.
Mohammad Alhyari
can you show me EIGRP config at the hub and the spokes ?
Mohammad.
HUB:
router eigrp RRRR
address-family ipv4 unicast vrf XXXXX autonomous-system 2550
  topology base
  exit-af-topology
  network 10.64.255.0 0.0.0.255
  network 172.31.255.0 0.0.0.31
exit-address-family
router eigrp 2550
network 192.168.255.0
router eigrp 2550
network 192.168.254.0
router eigrp RRRR
SPOKE 1:
router eigrp 2550
SPOKE 2:
router eigrp 2550
