09-11-2017 03:07 AM - edited 03-12-2019 04:31 AM
Hello All,
Could anyone please confirm if Cisco 881/K9 with ip services license and 1941/K9 with security license support Ikev2 and certificate based authentication as DMVPN clients. Appreciate if you could share any relevent document confirming the same.
Thanks a lot.
09-11-2017 10:48 AM - edited 09-11-2017 11:39 AM
This link confirms DMVPN is supported on a 881
https://www.cisco.com/c/en/us/products/routers/881-integrated-services-router-isr/index.html
And this link confirms FlexVPN is supported on a 881 and 1941, FlexVPN is IKEv2 only.
You can also use the Cisco Feature Navigator web site http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
So basically yes i'd say it is supported, best you lab the design. I'd make sure though you are using an up to date IOS firmware version.
09-12-2017 08:24 AM
