Dual ISP Hub and Spoke DMVPN
williamtwomey
Hello All,
I am trying to build a DMVPN solution for two sites each with secondary ISPs.
The solution works "sort of", but doesn't seem very robust (sometimes a router reload is required if VPN doesn't come up after ISP failover)
I was wondering if anyone had any suggestions to my config below?
Thanks!
!!!!HUB!!!!
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
crypto isakmp policy 3
hash md5
authentication pre-share
crypto isakmp key cisco123 address 0.0.0.0 0.0.0.0
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto ipsec profile dmvpn
set security-association lifetime seconds 1800
set transform-set aes256
set pfs group5
crypto ipsec profile dmvpn2
set pfs group5
interface Tunnel0
ip address 10.255.255.1 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 53
no ip split-horizon eigrp 53
ip nhrp authentication secret1
ip nhrp map multicast dynamic
ip nhrp network-id 6
ip nhrp holdtime 300
ip tcp adjust-mss 1360
delay 1000
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 545
tunnel protection ipsec profile dmvpn shared
interface Tunnel1
ip address 10.255.254.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 7
delay 1000
tunnel source FastEthernet0/0/0
tunnel key 546
tunnel protection ipsec profile dmvpn2 shared
interface Tunnel2
ip address 10.255.253.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 8
delay 1000
tunnel key 547
interface Tunnel3
ip address 10.255.252.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp network-id 9
delay 1000
tunnel key 548
interface FastEthernet0/0/0
description Secondary ISP
ip address 199.1.1.1 255.255.255.0
duplex auto
speed auto
interface VLAN1
description LAN
interface GigabitEthernet0/1
description Primary ISP
ip address 200.1.1.1 255.255.255.0
duplex auto
speed auto
router eigrp 53
network 10.255.252.0 0.0.0.255
network 10.255.253.0 0.0.0.255
network 10.255.254.0 0.0.0.255
network 10.255.255.0 0.0.0.255
network 192.168.1.0
eigrp stub connected
no auto-summary
ip route 0.0.0.0 0.0.0.0 199.1.1.2 5
ip route 0.0.0.0 0.0.0.0 200.1.1.2
control-plane
line con 0
line aux 0
line vty 0 4
login
end
!!!SPOKE!!!
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
memory-size iomem 5
ip cef
hash md5
set pfs group5
set pfs group5
interface VLAN1
ip address 192.168.0.1 255.255.255.0
no ip redirects
interface Tunnel0
ip address 10.255.255.5 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.255.255.1 200.1.1.1
ip nhrp map multicast 200.1.1.1
ip nhrp nhs 10.255.255.1
ip nhrp registration timeout 30
delay 1000
tunnel key 545
interface Tunnel1
ip address 10.255.254.5 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp map 10.255.254.1 199.1.1.1
ip nhrp map multicast 199.1.1.1
ip nhrp nhs 10.255.254.1
delay 1500
tunnel key 546
interface Tunnel2
ip address 10.255.253.5 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.255.253.1 200.1.1.1
ip nhrp nhs 10.255.253.1
delay 1000
tunnel key 547
interface Tunnel3
ip address 10.255.252.5 255.255.255.0
no ip redirects
ip mtu 1440
ip nhrp map 10.255.252.1 199.1.1.1
ip nhrp nhs 10.255.252.1
delay 1500
tunnel key 548
description Secondary Internet
ip address 201.1.1.1 255.255.255.0
duplex auto
speed auto
description Primary Internet
ip address 201.2.2.1 255.255.255.0
duplex auto
speed auto
router eigrp 53
distribute-list 1 out
network 192.168.0.0
offset-list 1 out 12800 Tunnel1
no auto-summary
ip route 0.0.0.0 0.0.0.0 201.2.2.2
ip route 0.0.0.0 0.0.0.0 201.1.1.2 5
access-list 1 permit 192.168.0.0
access-list 1 permit 10.255.255.0 0.0.0.255
access-list 1 permit 10.255.254.0 0.0.0.255
access-list 1 permit 10.255.253.0 0.0.0.255
access-list 1 permit 10.255.252.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
end
6 Replies 6
williamtwomey
These tunnels work, but EIGRP will sometimes not update the route. Does anyone have any insight into EIGRP in a setup like this?
William,
1) Missing DPDs. That will explain "sometimes a reload is required"
invalid-SPI-recovery will not help much, but you can keep it configured.
2) Stub on hub side? That's a bit odd isn't it? It's in fact not a stub. My suggestion is go phase3 design way and advertise summaries from hub. But that's up to you.
M.
Thanks for the response!
I left the stub on the hub while troubleshooting, it has since been removed.
By DPD, do you mean "crypto isakmp keepalive 10 periodic"?
I've since added that (spoke and hub) and while the tunnels work great (they fail over, can ping 10.255.25x.x) the routes do not update which lead me to believe it's an EIGRP problem. Is there something else I should do for DPD?
Thanks again
Will
Can't edit the original post, so:
!Hub
router eigrp 53
network 192.168.1.0
no auto-summary
!Spoke
router eigrp 53
network 192.168.0.0
no auto-summary
10 seconds periodic might be to steep if you want to scale.
Non-periodic 30/5 work OK for DMVPN :-)
Yes the problem with prefixes is not core DMVPN problem, most likelt the RP doing something odd (hence my suggestion to check the stubbines)
Try with BGP? :-)
Mlex1
Hello one question here on topology i want to configure second ISP but i can't if someone help me it will be wonderful thanks in advance, here in my topology with ISP1 my lab working and  i need isp2 for secondary what will i do 2f393ef6c4.png
Спрашивай все что хочешь
It would be better to start a new post for your issue.
You could setup a Dual Cloud DMPVN. Define 2 x tunnel interfaces, using a different tunnel source for each ISP and a separate network for the tunnel interface.
