610
ivanbarkic
Beginner
EZVPN C1841 problem
I have C1841 as EZVPN server and remote C1841 as EZVPN client. Connection between them is providers L3 VPN, so it is not over the internet. IPSec tunnels go up with no problem. Client is NEM. Problem is that traffic won't go via IPSec. No packets are encapsulated. I want all trafiic to go via tunnel, no split tunneling here. On client side Dialer0 is outside interface, since L3 VPN is over ADSL. On server's side I have only one interface connected to corporate network. Peer address is server's loopback address.
After IPSec is up, server gets remote subnets as static routes and redistribute them to OSPF. That part works fine, but remote site's traffic doesn't flow over IPSec to the coorporate LAN.
Could be TCP MSS or something like that?
Configuration:
EZVPN SERVER:
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 2
crypto isakmp policy 20
encr 3des
hash md5
group 2
crypto isakmp policy 30
encr 3des
group 2
crypto isakmp keepalive 20 10
crypto isakmp client configuration group XXXXXX
key XXXXXX
save-password
max-users 200
crypto ipsec transform-set TS1 esp-aes 256 esp-sha-hmac
crypto ipsec transform-set TS2 esp-3des esp-sha-hmac
crypto dynamic-map DYNMAPA 10
set transform-set TS1 TS2
reverse-route
crypto map CRYMAPA local-address Loopback0
crypto map CRYMAPA client authentication list VPN
crypto map CRYMAPA isakmp authorization list VPN
crypto map CRYMAPA client configuration address respond
crypto map CRYMAPA 10 ipsec-isakmp dynamic DYNMAPA
interface Loopback0
ip address 10.7.255.8 255.255.255.255
crypto map CRYMAPA
interface BVI1
ip address 172.16.0.254 255.255.255.0
crypto map CRYMAPA
EZVPN CLIENT:
crypto isakmp keepalive 10 5 periodic
crypto ipsec client ezvpn ADSLVPN
connect auto
group XXXX key XXXXX
local-address Dialer0
mode network-extension
peer 10.7.255.8
username xxxxx password xxxxxx
xauth userid mode local
interface FastEthernet0/1.10
description *** LAN INTERFACE 1 ***
crypto ipsec client ezvpn ADSLVPN inside
interface FastEthernet0/1.100
description *** LAN INTERFACE 2 ***
interface FastEthernet0/1.1000
description *** LAN INTERFACE 3 ***
interface Dialer0
description *** ADSL_VPN ***
ip address negotiated
ip mtu 1420
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
dialer idle-timeout 0
dialer persistent
no cdp enable
ppp authentication pap callin
ppp pap sent-username xxxxxxx password xxxxxxxx
2 REPLIES 2
Atul Singh
Beginner
Can you check if phase 2 SAs are formed by looking at "show crypto ipsec sa"? Traffic cannot go unencrypted if Phase 2 SA s are formed.
-Atul
ivanbarkic
Beginner
Well, the problem was in ASA FW that was in the middle of path, between EZVPN client and server.
Content for Community-Ad
