05-13-2020 05:32 PM - edited 05-13-2020 05:44 PM
There is a hub router and a few spokes routers in my network. The spokes work well with the hub but cannot set up tunnel between them from virtual-template.
HUB:
aaa new-model
aaa authorization network default local
aaa session-id common
crypto isakmp invalid-spi-recovery
crypto ikev2 fragmentation
crypto ikev2 authorization policy default
pool Spokes
route set interface
crypto ikev2 keyring My_key
peer Spokes
address 0.0.0.0 0.0.0.0
pre-shared-key local my_key
pre-shared-key remote my_key
crypto ikev2 profile My_IKEv2
match identity remote address 0.0.0.0
authentication remote pre-share
authentication local pre-share
keyring local My_key
aaa authorization group psk list default default
virtual-template 1
crypto ikev2 dpd 30 5 on-demand
crypto ipsec transform-set My_IKEv2 esp-gcm 256
mode tunnel
crypto ipsec profile default
set ikev2-profile My_IKEv2
set transform-set My_IKEv2
crypto ikev2 proposal default
no integrity
encryption aes-gcm-256
prf sha256
group 20
interface Loopback1
ip address 10.67.0.1 255.255.255.255
interface Virtual-Template1 type tunnel
ip mtu 1400
ip unnumbered lo1
ip nhrp network-id 10
ip nhrp redirect
ip tcp adjust-mss 1352
tunnel protection ipsec profile default
ip local pool Spokes 10.67.4.1 10.67.7.254
router eigrp 1
network 10.67.0.0 0.0.255.255
no passive-interface Loopback1
no passive-interface Virtual-Template1
Spoke1:
aaa new-model
peer Spokes
virtual-template 1
mode tunnel
no integrity
prf sha256
group 20
interface Tunnel20
ip address negotiated
ip access-group TUNIN in
ip access-group TUNOUT out
ip mtu 1400
ip nhrp shortcut virtual-template 1
ip nhrp redirect
tunnel source di0
tunnel destination my_hub_ip_address
ip unnumbered di0
ip mtu 1400
ip nhrp redirect
tunnel protection ipsec profile default ikev2-profile My_IKEv2
router eigrp 1
passive-interface default
no passive-interface Tunnel20
Spoke2:
aaa new-model
peer Spokes
virtual-template 1
mode tunnel
no integrity
prf sha256
group 20
interface Tunnel20
ip mtu 1400
ip nhrp redirect
tunnel source fa8
ip unnumbered fa8
ip mtu 1400
ip nhrp redirect
router eigrp 1
spoke1#show crypto ikev2 sa
IPv4 Crypto IKEv2 SA
Tunnel-id Local Remote fvrf/ivrf Status
1 spoke1_ip/500 hub_ip/500 none/none READY
Encr: AES-GCM, keysize: 256, PRF: SHA256, Hash: None, DH Grp:20, Auth sign: PSK, Auth verify: PSK
Life/Active Time: 86400/395 sec
2 spoke1_ip/500 spoke2_ip/500 none/none READY
Life/Active Time: 86400/8 sec
spoke2#sh crypto ikev2 sa
3 spoke2_ip/500 spoke1_ip/500 none/none DELETE
Life/Active Time: 300/117 sec
1 spoke2_ip/500 hub_ip/500 none/none READY
Life/Active Time: 86400/323 sec
IPv6 Crypto IKEv2 SA
debug spoke1:
000070: May 14 03:25:03.862 EET: IKEv2:(SESSION ID = 8,SA ID = 2):Building packet for encryption.
000071: May 14 03:25:03 EET: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to down
000072: May 14 03:25:30 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
000073: May 14 03:25:30.609 EET: IKEv2-ERROR:%Invalid msg context handle
000074: May 14 03:25:30.613 EET: IPSEC(crypto_ipsec_kmi_send_message): Invalid KMI msg id: 13
000075: May 14 03:25:30.613 EET: IPSEC(crypto_ipsec_send_ready): Couldn't send KMI message
000076: May 14 03:25:30.613 EET: insert of map into mapdb AVL failed, map + ace pair already exists on the mapdb
000077: May 14 03:25:30.613 EET: IPSEC: Expand action denied, discard or forward packet.
000078: May 14 03:25:30.613 EET: IPSEC: Expand action denied, notify RP
000079: May 14 03:25:30.613 EET: IPSEC: Expand action denied, discard or forward packet.
000080: May 14 03:25:30.613 EET: IPSEC: Expand action denied, discard or forward packet.
000081: May 14 03:25:32.597 EET: IKEv2:(SESSION ID = 9,SA ID = 2):Retransmitting packet
000082: May 14 03:25:32.597 EET: IKEv2:(SESSION ID = 9,SA ID = 2):Sending Packet [To spoke2_ip:500/From spoke1_ip:500/VRF i0:f0]
Initiator SPI : 9228A8F046534DA5 - Responder SPI : 38DBC6DE3E92DD9B Message id: 2
IKEv2 INFORMATIONAL Exchange REQUEST
Payload contents:
ENCR
000083: May 14 03:25:36.213 EET: IKEv2:(SESSION ID = 9,SA ID = 2):Retransmitting packet
000084: May 14 03:25:36.213 EET: IKEv2:(SESSION ID = 9,SA ID = 2):Sending Packet [To spoke2_ip:500/From spoke1_ip:500/VRF i0:f0]
Payload contents:
ENCR
debug spoke2:
000063: May 14 03:19:20 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
000064: May 14 03:19:21 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
000065: May 14 03:19:21 EET: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Virtual-Access1 (incomplete) - looped chain attempting to stack
000066: May 14 03:19:30 EET: %TUN-5-RECURDOWN: Virtual-Access1 temporarily disabled due to recursive routing
000067: May 14 03:19:30 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
000068: May 14 03:19:30 EET: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
000069: May 14 03:23:20 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
000070: May 14 03:23:20 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to up
000071: May 14 03:23:20 EET: %ADJ-5-PARENT: Midchain parent maintenance for IP midchain out of Virtual-Access1 (incomplete) - looped chain attempting to stack
000072: May 14 03:23:30 EET: %TUN-5-RECURDOWN: Virtual-Access1 temporarily disabled due to recursive routing
000073: May 14 03:23:30 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
000074: May 14 03:23:30 EET: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
000075: May 14 03:24:51 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
000076: May 14 03:24:51.938 EET: IKEv2-ERROR:%Invalid msg context handle
000077: May 14 03:24:51.938 EET: IPSEC(crypto_ipsec_kmi_send_message): Invalid KMI msg id: 13
000078: May 14 03:24:51.938 EET: IPSEC(crypto_ipsec_send_ready): Couldn't send KMI message
000079: May 14 03:24:51.942 EET: insert of map into mapdb AVL failed, map + ace pair already exists on the mapdb
000080: May 14 03:24:51.942 EET: IPSEC: Expand action denied, discard or forward packet.
000081: May 14 03:24:51.942 EET: IPSEC: Expand action denied, notify RP
000082: May 14 03:24:51.942 EET: IPSEC: Expand action denied, discard or forward packet.
000083: May 14 03:24:51.942 EET: IPSEC: Expand action denied, discard or forward packet.
000084: May 14 03:24:53.982 EET: IKEv2:(SESSION ID = 7,SA ID = 2):Retransmitting packet
000085: May 14 03:24:53.982 EET: IKEv2:(SESSION ID = 7,SA ID = 2):Sending Packet [To spoke1_ip:500/From spoke2_ip:500/VRF i0:f0]
Initiator SPI : F99EEE1B05876B31 - Responder SPI : E5DA75C2842D003C Message id: 2
Payload contents:
ENCR
000086: May 14 03:24:57.726 EET: IKEv2:(SESSION ID = 7,SA ID = 2):Retransmitting packet
000087: May 14 03:24:57.726 EET: IKEv2:(SESSION ID = 7,SA ID = 2):Sending Packet [To spoke1_ip:500/From spoke2_ip:500/VRF i0:f0]
Payload contents:
ENCR
000088: May 14 03:25:01 EET: %TUN-5-RECURDOWN: Virtual-Access1 temporarily disabled due to recursive routing
000089: May 14 03:25:01 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access1, changed state to down
000090: May 14 03:25:01.922 EET: IPSEC(delete_sa): deleting SA,
(sa) sa_dest= spoke2_ip, sa_proto= 50,
sa_spi= 0xDD0E58B0(3708704944),
sa_trans= esp-gcm 256 , sa_conn_id= 1014
sa_lifetime(k/sec)= (4608000/3600),
(identity) local= spoke2_ip:0, remote= spoke1_ip:0,
local_proxy= spoke2_ip/255.255.255.255/47/0,
remote_proxy= spoke1_ip/255.255.255.255/47/0
000091: May 14 03:25:01.922 EET: IPSEC(delete_sa): SA found saving DEL kmi
000092: May 14 03:25:01.922 EET: IPSEC(delete_sa): deleting SA,
(sa) sa_dest= spoke1_ip, sa_proto= 50,
sa_spi= 0xFAC73C11(4207361041),
sa_trans= esp-gcm 256 , sa_conn_id= 1013
000093: May 14 03:25:01 EET: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
000094: May 14 03:25:03.887 EET: IKEv2:(SESSION ID = 7,SA ID = 2):Retransmitting packet
000095: May 14 03:25:03.887 EET: IKEv2:(SESSION ID = 7,SA ID = 2):Sending Packet [To spoke1_ip:500/From spoke2_ip:500/VRF i0:f0]
Initiator SPI : F99EEE1B05876B31 - Responder SPI : E5DA75C2842D003C Message id: 3
Payload contents:
ENCR
000096: May 14 03:25:30.656 EET: IKEv2:Received Packet [From spoke1_ip:500/To spoke2_ip:500/VRF i0:f0]
Initiator SPI : 9228A8F046534DA5 - Responder SPI : 0000000000000000 Message id: 0
IKEv2 IKE_SA_INIT Exchange REQUEST
Payload contents:
SA KE N VID
000097: May 14 03:25:42.517 EET: IKEv2:(SESSION ID = 8,SA ID = 2):Received Packet [From spoke1_ip:500/To spoke2_ip:500/VRF i0:f0]
Initiator SPI : 9228A8F046534DA5 - Responder SPI : 38DBC6DE3E92DD9B Message id: 4
Payload contents:
DELETE NOTIFY(DELETE_REASON)
000098: May 14 03:25:42.517 EET: IKEv2:(SESSION ID = 8,SA ID = 2):
000099: May 14 03:25:42 EET: %LINK-3-UPDOWN: Interface Virtual-Access1, changed state to down
Solved! Go to Solution.
05-14-2020 02:17 PM
This trouble has resolved! I changed in my spokes in unnumbered interface:
ip unnumbered Tunnel10
05-14-2020 01:56 AM
You've got a routing loop %TUN-5-RECURDOWN: Virtual-Access1 temporarily disabled due to recursive routing
You'll learn the routes via the hub, so remove "no passive-interface Virtual-Template1" and try again.
05-14-2020 06:43 AM
I disabled eigrp on passive-interface Virtual-Template1 in my hub. The trouble still exist.
router eigrp 1
There aren’t log messages on my hub when I am trying to ping one spoke from other
hub#show debugging
EIGRP:
Route Event debugging is on
EIGRP-IPv4: Address-Family:
IKEV2:
IKEv2 error debugging is on
IKEv2 default debugging is on
Spoke1:
Spoke1#show debugging
EIGRP:
Packet debugging is on
IKEV2:
Cryptographic Subsystem:
Crypto IPSEC debugging is on
Crypto IPSEC Error debugging is on
Spoke2:
Spoke2#show debugging
EIGRP:
IKEV2:
Spoke1 log:
012701: May 14 16:32:13.953 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012702: May 14 16:32:15.005 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012703: May 14 16:32:15.005 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012704: May 14 16:32:18.829 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012705: May 14 16:32:18.829 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012706: May 14 16:32:19.709 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012707: May 14 16:32:19.709 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012708: May 14 16:32:21 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
012709: May 14 16:32:21.973 EET: IKEv2-ERROR:%Invalid msg context handle
012710: May 14 16:32:21.977 EET: IPSEC(crypto_ipsec_kmi_send_message): Invalid KMI msg id: 13
012711: May 14 16:32:21.977 EET: IPSEC(crypto_ipsec_send_ready): Couldn't send KMI message
012712: May 14 16:32:21.977 EET: insert of map into mapdb AVL failed, map + ace pair already exists on the mapdb
012713: May 14 16:32:21.977 EET: IPSEC: Expand action denied, discard or forward packet.
012714: May 14 16:32:21.977 EET: IPSEC: Expand action denied, notify RP
012715: May 14 16:32:21.977 EET: IPSEC: Expand action denied, discard or forward packet.
012716: May 14 16:32:21.977 EET: IPSEC: Expand action denied, discard or forward packet.
012717: May 14 16:32:23.425 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012718: May 14 16:32:23.425 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012719: May 14 16:32:24.013 EET: IKEv2:(SESSION ID = 191,SA ID = 2):Retransmitting packet
012720: May 14 16:32:24.013 EET: IKEv2:(SESSION ID = 191,SA ID = 2):Sending Packet [To spoke2_ip:500/From spoke1_ip:500/VRF i0:f0]
Initiator SPI : 584162B685FD3660 - Responder SPI : 5F758222BB7B3F31 Message id: 2
Payload contents:
ENCR
012721: May 14 16:32:27.853 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012722: May 14 16:32:27.853 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012723: May 14 16:32:27.953 EET: IKEv2:(SESSION ID = 191,SA ID = 2):Retransmitting packet
012724: May 14 16:32:27.953 EET: IKEv2:(SESSION ID = 191,SA ID = 2):Sending Packet [To spoke2_ip:500/From spoke1_ip:500/VRF i0:f0]
012725: May 14 16:32:28.685 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012726: May 14 16:32:28.685 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012727: May 14 16:32:31 EET: %TUN-5-RECURDOWN: Virtual-Access3 temporarily disabled due to recursive routing
012728: May 14 16:32:31 EET: %LINEPROTO-5-UPDOWN: Line protocol on Interface Virtual-Access3, changed state to down
012729: May 14 16:32:31.969 EET: IPSEC(delete_sa): deleting SA,
sa_spi= 0x31A70158(833028440),
sa_trans= esp-gcm 256 , sa_conn_id= 1406
(identity) local= spoke1_ip:0, remote= spoke2_ip:0,
local_proxy= spoke1_ip/255.255.255.255/47/0,
remote_proxy= spoke2_ip/255.255.255.255/47/0
012730: May 14 16:32:31.969 EET: IPSEC(delete_sa): SA found saving DEL kmi
012731: May 14 16:32:31.969 EET: IPSEC(delete_sa): deleting SA,
sa_spi= 0x557FBC1B(1434434587),
sa_trans= esp-gcm 256 , sa_conn_id= 1405
012732: May 14 16:32:31 EET: %LINK-3-UPDOWN: Interface Virtual-Access3, changed state to down
012733: May 14 16:32:33.349 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012734: May 14 16:32:33.349 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012735: May 14 16:32:33.805 EET: IKEv2:(SESSION ID = 191,SA ID = 2):Retransmitting packet
012736: May 14 16:32:33.805 EET: IKEv2:(SESSION ID = 191,SA ID = 2):Sending Packet [To spoke2_ip:500/From spoke1_ip:500/VRF i0:f0]
Initiator SPI : 584162B685FD3660 - Responder SPI : 5F758222BB7B3F31 Message id: 3
Payload contents:
ENCR
012737: May 14 16:32:37.126 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012738: May 14 16:32:37.126 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012739: May 14 16:32:37.902 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012740: May 14 16:32:37.902 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012741: May 14 16:32:42.002 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012742: May 14 16:32:42.002 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012743: May 14 16:32:42.350 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012744: May 14 16:32:42.350 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012745: May 14 16:32:46.858 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012746: May 14 16:32:46.858 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012747: May 14 16:32:46.982 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
Spoke2 log:
012703: May 14 16:32:12.105 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012704: May 14 16:32:12.105 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012705: May 14 16:32:12.769 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012706: May 14 16:32:12.769 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012707: May 14 16:32:16.982 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012708: May 14 16:32:16.982 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012709: May 14 16:32:17.326 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012710: May 14 16:32:17.326 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012711: May 14 16:32:21.714 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012712: May 14 16:32:21.714 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012713: May 14 16:32:21.986 EET: IKEv2:Received Packet [From spoke1_ip:500/To spoke2_ip:500/VRF i0:f0]
Initiator SPI : 584162B685FD3660 - Responder SPI : 0000000000000000 Message id: 0
012714: May 14 16:32:26.038 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012715: May 14 16:32:26.038 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012716: May 14 16:32:27.086 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012717: May 14 16:32:27.086 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012718: May 14 16:32:30.822 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012719: May 14 16:32:30.822 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012720: May 14 16:32:31.662 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012721: May 14 16:32:31.662 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012722: May 14 16:32:33.810 EET: IKEv2:(SESSION ID = 190,SA ID = 2):Received Packet [From spoke1_ip:500/To spoke2_ip:500/VRF i0:f0]
Payload contents:
DELETE
012723: May 14 16:32:33.810 EET: IKEv2:(SESSION ID = 190,SA ID = 2):Building packet for encryption.
012724: May 14 16:32:35.666 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012725: May 14 16:32:35.666 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012726: May 14 16:32:36.558 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012727: May 14 16:32:36.558 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012728: May 14 16:32:40.447 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012729: May 14 16:32:40.451 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012730: May 14 16:32:41.547 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012731: May 14 16:32:41.547 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012732: May 14 16:32:44.883 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
012733: May 14 16:32:44.883 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0 peerQ un/rely 0/0
012734: May 14 16:32:45.839 EET: EIGRP: Sending HELLO on Tu20 - paklen 20
012735: May 14 16:32:45.839 EET: AS 1, Flags 0x0:(NULL), Seq 0/0 interfaceQ 0/0 iidbQ un/rely 0/0
012736: May 14 16:32:49.427 EET: EIGRP: Received HELLO on Tu20 - paklen 20 nbr 10.67.0.2
If you require any further information, feel free to contact me.
05-14-2020 02:17 PM
