Help on establishing Ipsec tunnel btw 1941 and ASA
   We are creating an Ipsec tunnel over the internet to another site but is not working, could someone help me on what could be happening?
My config:
version 15.1
hostname XXXX
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable XXXXX
enable password XXXXXX
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name yourdomain.com
ip name-server XXX.XXX.XXX.XXX
password encryption aes
crypto pki trustpoint TP-self-signed-4075439344
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4075439344
revocation-check none
rsakeypair TP-self-signed-4075439344
crypto pki certificate chain TP-self-signed-4075439344
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303735 34333933 3434301E 170D3131 30393139 30323236
  34365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30373534
  33393334 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A35E B6AC0BE0 57A53B45 8CF23671 F91A18AC 09F29E6D AEC70F4D EF3BDCD6
  269BFDED 44E26A98 7A1ABCAA DB756AFC 719C3D84 8B605C2A 7E99AF79 B72A84BC
  89046B2D 967BB775 978EF14D A0BD8036 523B2AE1 1890EB38 BCA3333B 463D1267
  22050A4F EAF4985A 7068024A A0425CE7 D3ADF5F5 C02B2941 67C9B654 6A7EF689
  049B0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1408B59A 57733D6E 157876B3 72A91F28 F8D95BAB D2301D06
  03551D0E 04160414 08B59A57 733D6E15 7876B372 A91F28F8 D95BABD2 300D0609
  2A864886 F70D0101 05050003 81810094 ED574BFE 95868A5D B539A70F 228CC08C
  E26591C2 16DF19AB 7A177688 D7BB1CCB 5CFE4CB6 25F0DDEB 640E6EFA 58636DC0
  238750DD 1ACF8902 96BB39B5 5B2F6DEC CB97CF78 23510943 E09801AF 8EB54020
  DF496E25 B787126F D1347022 58900537 844EF865 36CB8DBD 79918E4B 76D00196
  DD9950CB A40FC91B 4BCDE0DC 1B217A
        quit
license udi pid CISCO1941/K9 sn FTX1539816K
license boot module c1900 technology-package securityk9
username XXXXXXXXXXXXXX
redundancy
crypto isakmp policy 60
encr aes
authentication pre-share
group 2
crypto isakmp key XXXXXXX address XXX.XXX.XXX.XXX
crypto isakmp profile mode
   keyring default
   self-identity address
   match identity host XXX.XXX.XXX.XXX
   initiate mode aggressive
crypto ipsec transform-set VPNbrasil esp-aes esp-sha-hmac
crypto map outside 60 ipsec-isakmp
set peer XXX.XXX.XXX.XXX
set transform-set VPNbrasil
set pfs group2
match address vpnbrazil
interface Tunnel0
ip unnumbered GigabitEthernet0/1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description WAN
ip address XXX.XXX.XXX.XXX 255.255.255.248
ip nat outside
no ip virtual-reassembly in
duplex full
speed 100
crypto map outside
interface GigabitEthernet0/1
description Intercon_LAN
ip address XXX.XXX.XXX.XXX 255.255.255.252
ip nat inside
duplex auto
speed auto
crypto map outside
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 2 interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.XXX name Internet
ip access-list extended natvpnout
permit ip host XXX.XXX.XXX.XXX any
permit ip any any
ip access-list extended vpnbrazil
permit icmp XXX.XXX.XXX.XXX 0.0.0.255 any
permit icmp any XXX.XXX.XXX.XXX 0.0.0.255
permit ip any any
access-list 1 permit any
access-list 2 permit XXX.XXX.XXX.XXX 0.0.0.1 log
access-list 2 permit XXX.XXX.XXX.XXX 0.0.0.7
access-list 3 permit XXX.XXX.XXX.XXX
access-list 23 permit XXX.XXX.XXX.XXX 0.0.0.7
access-list 23 permit any log
control-plane
b!
line con 0
login local
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input all
telnet transparent
line vty 5
access-class 23 in
privilege level 15
login
transport input all
telnet transparent
line vty 6 15
access-class 23 in
access-class 23 out
privilege level 15
login local
transport input telnet ssh
transport output all
Could someone please help me on what could be wrong? and What tests should I do?
Rds,
Luiz
nine_2012
Beginner
Beginner
try a simple configuration w/o isakmp proflies
have a look at this link:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00805e8c80.shtml
Recognize Your Peers
