11-22-2004 03:30 PM
I have a Cisco 3725 and a NM-1CE1T1-PRI card. I need help configuring this card. Does anyone have a sample config?
11-22-2004 06:37 PM
config ter
card type t1 slot
controller t1 slot/port
linecode {ami | b8zs}
framing {sf | esf}
clock source {line | internal}
pri-group [timeslots range]
NOTE: this card can be configured as a T1 or E1 interface for PRI or CAS signaling.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_feature_guide09186a00801af22a.html
Do you intend to terminate ISDN calls or modem calls on the c3725?
For modem and/or ISDN calls:
Thanks, Mak
11-23-2004 05:27 AM
I will be terminating modem calls on the c3725.
thanks,
I will read the "for modem and/or ISDN calls" above.
