I'm trying to setup a hairpin configuration to let the vpn clients connect to the head-office and at the same time to the sub-office which is connected with a VPN tunnel.
Situation:
Client
Subnet
10.10.12.x
Head office
Subnet
192.168.12.x
Sub office
Subnet
192.168.14.x
Client connects to the Head office, can connect to subnet 192.168.14.x and must also connect to 192.168.12.x
What do I need to configure (is is possible through ASDM?)
I tried to configure the asa by watching this video, but can't get it to work..
3 things. You must allow traffic to enter/exit same interface at Head office.
same-security-traffic permit intra-interface
You must then add the new traffic to the existing acl's for the lan to lan vpn.
Head End
access-list xxx extended permit ip 10.10.12.0 255.255.255.0 192.168.14.0 255.255.255.0
Suboffice
access-list xxx extended permit ip 192.168.14.0 255.255.255.0 10.10.12.0 255.255.255.0
and also the nat 0 at suboffice
access-list nat0 extended permit ip 192.168.14.0 255.255.255.0 10.10.12.0 255.255.255.0
nat(inside) 0 access-list nat0
This is all possible via ASDM as well.
