2510
Ken Mackay
Beginner
HUB & SPOKE environment with ASA5512 as the HUB and ASA5505 as spoke.
I can't seem to get by the error's. Phase 1 completes, then the errors start, 7.0.0.2 recieved non-routine notify message no proposal choosen, connection terminated for peer 7.0.0.2 reason peer terminate remote proxy N/A local Proxy N/A, 7.0.0.2 removing peer from correlator table failed, no match, seesion being torn down reason user requested, group 7.0.0.2 automatic NAT detection status remote end is not behind NAT device, this end is not behind NAT device. The other end the ASA5512 I get IP 7.1.0.2 no valid authentication type found for the tunnel group, Remote end is not behind NAT device, the DAP records were selected for connection DfltAccessPolicy, Phase 1 completed, All IPSEC SA proposals found unacceptable, IP 7.1.0.2 QM FSM error, removing peer from correlator table failed no match, 7.1.0.2 session being torn down reason Phase 2 Mismatch, 7.1.0.2 session disconnected type IKEV1, recevied encrypted packet with no matchin SA dropping.
I have searched internet and found many results however as changes implemented I always end back at this point. Any HELP would be greatly appreciated. Lost two days in the LAB. I will post configs. This a test soon to go into production. Thanks
Ken
ASA1# sho run
: Saved
ASA Version 9.1(2)
hostname ASA1
domain-name TEST1.CA
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface GigabitEthernet0/0
 nameif Outside
 security-level 100
 ip address 7.0.0.2 255.255.255.0
interface GigabitEthernet0/1
 nameif AS1toR1
 security-level 50
 ip address 1.0.0.2 255.255.255.0
interface GigabitEthernet0/2
 nameif AS1toR2
 security-level 50
 ip address 3.0.0.2 255.255.255.0
interface GigabitEthernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet0/5
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 management-only
 nameif management
 security-level 0
ftp mode passive
dns domain-lookup Outside
dns domain-lookup AS1toR1
dns domain-lookup AS1toR2
dns domain-lookup management
dns server-group DefaultDNS
 name-server 201.201.201.201
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj-1.0.0.0
object network 2.0.0.0
 subnet 2.0.0.0 255.255.255.0
object network 6.0.0.0
 subnet 6.0.0.0 255.255.255.0
object network 7.1.0.0
 subnet 7.1.0.0 255.255.255.0
object network 8.0.0.0
 subnet 8.0.0.0 255.255.255.0
object network 9.0.0.0
 subnet 9.0.0.0 255.255.255.0
object-group network DM_INLINE_NETWORK_3
 network-object 1.0.0.0 255.255.255.0
 network-object 3.0.0.0 255.255.255.0
 network-object object 2.0.0.0
 network-object object 8.0.0.0
object-group network DM_INLINE_NETWORK_4
 network-object object 6.0.0.0
 network-object object 9.0.0.0
object-group network DM_INLINE_NETWORK_1
object-group network DM_INLINE_NETWORK_2
object-group network DM_INLINE_NETWORK_5
object-group network DM_INLINE_NETWORK_6
access-list HEADEND extended permit ip any any
access-list hq-to-vpnend extended permit ip object-group DM_INLINE_NETWORK_3 object-group DM_INLINE_NETWORK_4
access-list vpnend-to-hq extended permit ip object-group DM_INLINE_NETWORK_1 object-group DM_INLINE_NETWORK_2
access-list Outside_cryptomap_15 extended permit ip object-group DM_INLINE_NETWORK_5 object-group DM_INLINE_NETWORK_6
access-list Outside_access_in extended permit ip any any
access-list Outside_access_in extended permit icmp any4 any4
access-list AS1toR2_access_in extended permit icmp any4 any4
access-list AS1toR2_access_in extended permit ip any any
access-list AS1toR1_access_in extended permit ip any any
access-list AS1toR1_access_in extended permit icmp any4 any4
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu AS1toR1 1500
mtu AS1toR2 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
access-group Outside_access_in in interface Outside
access-group AS1toR1_access_in in interface AS1toR1
access-group AS1toR2_access_in in interface AS1toR2
router ospf 1
 network 1.0.0.0 255.255.255.0 area 0
 network 3.0.0.0 255.255.255.0 area 0
 network 7.0.0.0 255.255.255.0 area 0
 log-adj-changes
route Outside 0.0.0.0 0.0.0.0 7.0.0.1 125
route Outside 6.0.0.0 255.255.255.0 7.0.0.1 125
route Outside 9.0.0.0 255.255.255.0 7.0.0.1 125
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
eou allow none
http server enable
http 192.168.1.2 255.255.255.255 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
sysopt connection preserve-vpn-flows
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec ikev1 transform-set MAP-VPN1 esp-3des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal AES256
 protocol esp encryption aes-256
 protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
 protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal 3DES
 protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal DES
 protocol esp encryption des
crypto ipsec security-association pmtu-aging infinite
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 match address Outside_cryptomap_15
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set ikev1 transform-set MAP-VPN1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 5 set reverse-route
crypto dynamic-map DYNMAP 10 set pfs
crypto dynamic-map DYNMAP 10 set ikev1 transform-set MAP-VPN1
crypto dynamic-map DYNMAP 10 set reverse-route
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map HQ2REMOTE 10 ipsec-isakmp dynamic DYNMAP
crypto map HQ2REMOTE interface Outside
crypto ca trustpool policy
crypto ikev1 enable Outside
crypto ikev1 policy 1
 authentication pre-share
 encryption 3des
 hash md5
 group 2
 lifetime 28800
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
vpn-addr-assign local reuse-delay 30
vpn load-balancing
 interface lbpublic Outside
 interface lbprivate AS1toR1
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
 enable Outside
 no anyconnect-essentials
group-policy DfltGrpPolicy attributes
 wins-server value 10.10.10.10
 dns-server value 201.201.201.201
 vpn-idle-timeout none
 vpn-tunnel-protocol ikev1 l2tp-ipsec ssl-clientless
 split-tunnel-network-list value HEADEND
 default-domain value TEST1.CA
 webvpn
  activex-relay disable
tunnel-group DefaultL2LGroup ipsec-attributes
 ikev1 pre-shared-key *****
tunnel-group DefaultRAGroup general-attributes
 secondary-authentication-server-group LOCAL
 authorization-server-group LOCAL
 nat-assigned-to-public-ip Outside
tunnel-group DefaultRAGroup ipsec-attributes
 peer-id-validate nocheck
 ikev1 user-authentication none
tunnel-group DefaultWEBVPNGroup general-attributes
tunnel-group DefaultWEBVPNGroup ipsec-attributes
tunnel-group-map default-group DefaultL2LGroup
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly 24
  subscribe-to-alert-group configuration periodic monthly 24
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:022709234965ad8943628e790ed5ed1f
: end
ASA1#
ASA2# sho run
: Saved
ASA Version 8.2(5)
hostname ASA2
domain-name TEST2.CA
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 switchport access vlan 14
interface Ethernet0/1
 switchport access vlan 24
interface Ethernet0/2
 shutdown
interface Ethernet0/3
 shutdown
interface Ethernet0/4
 shutdown
interface Ethernet0/5
 shutdown
interface Ethernet0/6
 shutdown
interface Ethernet0/7
 switchport access vlan 4
interface Vlan1
 no nameif
 no security-level
 no ip address
interface Vlan4
 nameif management.
 security-level 0
 ip address 192.168.1.101 255.255.255.0
 management-only
interface Vlan14
 nameif Outside
 security-level 100
 ip address dhcp setroute
interface Vlan24
 nameif Inside
 security-level 50
 ip address 6.0.0.2 255.255.255.0
ftp mode passive
dns domain-lookup management.
dns domain-lookup Inside
 network-object 2.0.0.0 255.255.255.0
 network-object 8.0.0.0 255.255.255.0
 network-object 6.0.0.0 255.255.255.0
 network-object 9.0.0.0 255.255.255.0
access-list REMOTEEND extended permit ip any any
access-list hq-to-vpnend extended permit ip object-group DM_INLINE_NETWORK_5 object-group DM_INLINE_NETWORK_6
access-list Outside_access_in extended permit icmp any any
access-list Inside_access_in extended permit ip any any
access-list Inside_access_in extended permit icmp any any
pager lines 24
logging enable
mtu management. 1500
mtu Outside 1500
mtu Inside 1500
no failover
arp timeout 14400
access-group Inside_access_in in interface Inside
router ospf 1
 network 6.0.0.0 255.255.255.0 area 0
 network 7.1.0.0 255.255.255.0 area 0
 log-adj-changes
route Outside 1.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 2.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 3.0.0.0 255.255.255.0 7.0.0.2 125
route Outside 8.0.0.0 255.255.255.0 7.0.0.2 125
 network-acl REMOTEEND
eou allow none
http server enable
http 0.0.0.0 0.0.0.0 management.
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set MAP-VPN1 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set MAP-VPN1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set reverse-route
crypto map HQ2REMOTE 15 match address vpnend-to-hq
crypto map HQ2REMOTE 15 set pfs
crypto map HQ2REMOTE 15 set connection-type originate-only
crypto map HQ2REMOTE 15 set peer 7.0.0.2
crypto map HQ2REMOTE 15 set transform-set MAP-VPN1
crypto map HQ2REMOTE 15 set security-association lifetime seconds 28800
crypto map HQ2REMOTE 15 set security-association lifetime kilobytes 4608000
crypto map HQ2REMOTE 15 set reverse-route
crypto map HQ2REMOTE 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto isakmp enable Outside
crypto isakmp policy 15
 encryption 3des
 hash md5
 group 2
 lifetime 28800
crypto isakmp ipsec-over-tcp port 10000
vpn-addr-assign local reuse-delay 5
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface Outside
ssl encryption 3des-sha1
webvpn
 enable Outside
 vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
 split-tunnel-network-list value REMOTEEND
 default-domain value TEST2.CA
 smartcard-removal-disconnect disable
tunnel-group 7.0.0.2 type ipsec-l2l
tunnel-group 7.0.0.2 ipsec-attributes
tunnel-group-map default-group 7.0.0.2
 parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect ip-options
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
call-home
 profile CiscoTAC-1
  no active
Cryptochecksum:0d04273f55e788e2a4ad4d025084d33d
: end
ASA2#
1 ACCEPTED SOLUTION
Jon Marshall
VIP Community Legend
Mike
It's been a while since I did these but on your ASA 9.1 you are using the dynamic map called DYNMAP but you haven't told it what the IPs are to match ie. shouldn't you have -
crypto dynamic-map DYNMAP 10 match address <acl name>  <--- you have multiple acls for the same thing so not sure what you want to use.
Also you don't need all those additional route entries for the crypto subnets pointing to the outside ie. the default route is enough but it won't hurt.
Jon
75 REPLIES 75
Jon Marshall
Mike
Jon
Thanks Mike. You were correct on the "mach address <acl name> have changed that to <hq-to-vpnend> Also removed the excess route entries for the crypto. But still recieving the same errors??? Do you see anything else wrong with the config?
Ken
Ken
Sorry, I have no idea why I called you Mike :-)
Can you do a full debug on the ASA 9.1 and post the output.
Jon
Hey I made the same mistake Jon, with your name forgive me :) Jon can you be more specfic there is no debug all command.
Ken
Ken
Sorry, try these commands -
debug crypto isakmp 127
debug crypto IPsec 127
and then try to initiate the VPN.
Jon
Jon
Was able to get something from "debug crypto isakmp 127" however nothing from "debug crypto ipsec 127"
ASA1(config)# debug crypto isakmp 127
ASA1(config)# Mar 02 10:32:53 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultRAGroup
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, No valid authentication type found for the tunnel group
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, IKE: Filter conflict: received filter-ID (filter name=no filter) along with an AV-PAIR dynamic ACL filter (filter name = DAP-ip-user-A0F3D00B).AV-PAIR dynamic filter will be applied.
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, User () authenticated.
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, All IPSec SA proposals found unacceptable!
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fff9f9014a0, mess id 0xff7684e6)!
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 02 10:32:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Session is being torn down. Reason: Phase 2 Mismatch
Mar 02 10:32:53 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
ASA1(config)# Mar 02 10:33:23 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultRAGroup
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, No valid authentication type found for the tunnel group
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, IKE: Filter conflict: received filter-ID (filter name=no filter) along with an AV-PAIR dynamic ACL filter (filter name = DAP-ip-user-A0F3D00B).AV-PAIR dynamic filter will be applied.
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, User () authenticated.
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, All IPSec SA proposals found unacceptable!
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fff9f9014a0, mess id 0x42ebba46)!
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 02 10:33:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Session is being torn down. Reason: Phase 2 Mismatch
Mar 02 10:33:23 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
ASA1(config)# Mar 02 10:33:53 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultRAGroup
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, No valid authentication type found for the tunnel group
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, IKE: Filter conflict: received filter-ID (filter name=no filter) along with an AV-PAIR dynamic ACL filter (filter name = DAP-ip-user-A0F3D00B).AV-PAIR dynamic filter will be applied.
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, User () authenticated.
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, All IPSec SA proposals found unacceptable!
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fff9f9014a0, mess id 0x66195caf)!
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 02 10:33:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Session is being torn down. Reason: Phase 2 Mismatch
Mar 02 10:33:53 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
ASA1(config)# debug crypto ipsec 127
ASA1(config)#
ASA1(config)#
ASA1(config)#
ASA1(config)#
Ken
Ken
Your crypto map acls are referencing object groups on each ASA.
Can you modify the object-groups on the ASA running 9.1 to match the 8.4 ones ie. you have used 255.255.255.0 subnet masks on all the networks in the 8.4 configuration but not on the 9.1.
Can you make them match exactly and try again.
Jon
Jon
All networks have the subnet masks of 255.255.255.0 although it doesn't appear so in the above posted configs. I believe it has something to do with different ASA's and code versions.
Ken
Ken
Okay thanks.
Did you see my last post about adding that command to your DefaultL2LGroup ?
If you have added it can you run the debug crypto isakmp 127 command again to make sure it is using the right group this time.
Jon
Jon,
I was unable to add that command however DefaultL2LGroup is the default when reviewing in the Cisco ASDM on both ASA's.
ASA1(config)# Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 168
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, processing SA payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Oakley proposal is acceptable
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, processing VID payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 02 VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 03 VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal RFC VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Received Fragmentation VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, processing IKE SA payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, IKE SA Proposal # 1, Transform # 1 acceptable  Matches global IKE entry # 2
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ISAKMP SA payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Traversal VID ver RFC payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Fragmentation VID + extended capabilities payload
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 124
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, processing ke payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, processing ISA_KE payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, processing nonce payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Received Cisco Unity client VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Received xauth V6 VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Processing VPN3000/ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Received Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, processing NAT-Discovery payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, computing NAT Discovery hash
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ke payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing nonce payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Cisco Unity VID payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing xauth V6 VID payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Send IOS VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing VID payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Discovery payload
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultRAGroup
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, No valid authentication type found for the tunnel group
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Generating keys for Responder...
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing ID payload
Mar 02 12:02:53 [IKEv1 DECODE]Group = DefaultRAGroup, IP = 7.1.0.2, ID_IPV4_ADDR ID received
7.1.0.2
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Computing hash for ISAKMP
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Processing IOS keep alive payload: proposal=32767/32767 sec.
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing VID payload
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received DPD VID
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing ID payload
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing hash payload
Mar 02 12:02:53 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing IOS keep alive payload: proposal=32767/32767 sec.
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing dpd vid payload
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 101
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: primary DNS = 201.201.201.201
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: secondary DNS = cleared
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: primary WINS = 10.10.10.10
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: secondary WINS = cleared
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: split tunneling list = HEADEND
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: default domain = TEST1.CA
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: IP Compression = disabled
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: Split Tunneling Policy = Disabled
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: Browser Proxy Setting = no-modify
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: Browser Proxy Bypass Local = disable
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, IKE: Filter conflict: received filter-ID (filter name=no filter) along with an AV-PAIR dynamic ACL filter (filter name = DAP-ip-user-A0F3D00B).AV-PAIR dynamic filter will be applied.
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, User () authenticated.
Mar 02 12:02:53 [IKEv1 DECODE]IP = 7.1.0.2, IKE Responder starting QM: msg id = 29cf9586
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Delay Quick Mode processing, Cert/Trans Exch/RM DSID in progress
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Resume Quick Mode processing, Cert/Trans Exch/RM DSID completed
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, Keep-alive type for this connection: DPD
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Starting P1 rekey timer: 24480 seconds.
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=29cf9586) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + KE (4) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 320
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing SA payload
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing nonce payload
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing ke payload
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing ISA_KE for PFS in phase 2
7.1.0.2
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Received remote Proxy Host data in ID Payload:  Address 7.1.0.2, Protocol 0, Port 0
7.0.0.2
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Received local Proxy Host data in ID Payload:  Address 7.0.0.2, Protocol 0, Port 0
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, QM IsRekeyed old sa not found by addr
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Static Crypto Map check, map DYNMAP, seq = 10 is a successful match
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, IKE Remote Peer configured for crypto map: DYNMAP
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing IPSec SA payload
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, All IPSec SA proposals found unacceptable!
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, sending notify message
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing ipsec notify payload for msg id 29cf9586
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=126f12e9) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fff9e5d3850, mess id 0x29cf9586)!
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKE QM Responder FSM error history (struct &0x00007fff9e5d3850)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, sending delete/delete with reason message
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKE SA MM:14a47a0b rcv'd Terminate: state MM_ACTIVE  flags 0x0001c042, refcnt 1, tuncnt 0
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKE SA MM:14a47a0b terminating:  flags 0x0101c002, refcnt 0, tuncnt 0
Mar 02 12:02:53 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing IKE delete payload
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=ca6774f2) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Mar 02 12:02:53 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Session is being torn down. Reason: Phase 2 Mismatch
Mar 02 12:02:53 [IKEv1]Ignoring msg to mark SA with dsID 1896448 dead because SA deleted
Mar 02 12:02:53 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 168
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, processing SA payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Oakley proposal is acceptable
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, processing VID payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 02 VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal ver 03 VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Received NAT-Traversal RFC VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Received Fragmentation VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, IKE Peer included IKE fragmentation capability flags:  Main Mode:        True  Aggressive Mode:  True
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, processing IKE SA payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, IKE SA Proposal # 1, Transform # 1 acceptable  Matches global IKE entry # 2
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ISAKMP SA payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Traversal VID ver RFC payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Fragmentation VID + extended capabilities payload
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 124
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, processing ke payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, processing ISA_KE payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, processing nonce payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Received Cisco Unity client VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Received xauth V6 VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Processing VPN3000/ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Received Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, processing NAT-Discovery payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, computing NAT Discovery hash
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing ke payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing nonce payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing Cisco Unity VID payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing xauth V6 VID payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Send IOS VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing VID payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, constructing NAT-Discovery payload
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, Connection landed on tunnel_group DefaultRAGroup
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, No valid authentication type found for the tunnel group
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Generating keys for Responder...
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (20) + NAT-D (20) + NONE (0) total length : 296
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 92
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing ID payload
Mar 02 12:03:23 [IKEv1 DECODE]Group = DefaultRAGroup, IP = 7.1.0.2, ID_IPV4_ADDR ID received
7.1.0.2
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing hash payload
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Computing hash for ISAKMP
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Processing IOS keep alive payload: proposal=32767/32767 sec.
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing VID payload
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Received DPD VID
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Automatic NAT Detection Status:     Remote end is NOT behind a NAT device     This   end is NOT behind a NAT device
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing ID payload
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing hash payload
Mar 02 12:03:23 [IKEv1 DEBUG]IP = 7.1.0.2, Constructing IOS keep alive payload: proposal=32767/32767 sec.
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing dpd vid payload
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + IOS KEEPALIVE (128) + VENDOR (13) + NONE (0) total length : 101
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: primary DNS = 201.201.201.201
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: secondary DNS = cleared
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: primary WINS = 10.10.10.10
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: secondary WINS = cleared
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: split tunneling list = HEADEND
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: default domain = TEST1.CA
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: IP Compression = disabled
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: Split Tunneling Policy = Disabled
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: Browser Proxy Setting = no-modify
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKEGetUserAttributes: Browser Proxy Bypass Local = disable
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, IKE: Filter conflict: received filter-ID (filter name=no filter) along with an AV-PAIR dynamic ACL filter (filter name = DAP-ip-user-A0F3D00B).AV-PAIR dynamic filter will be applied.
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, User () authenticated.
Mar 02 12:03:23 [IKEv1 DECODE]IP = 7.1.0.2, IKE Responder starting QM: msg id = 4203010f
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Delay Quick Mode processing, Cert/Trans Exch/RM DSID in progress
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Resume Quick Mode processing, Cert/Trans Exch/RM DSID completed
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, PHASE 1 COMPLETED
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, Keep-alive type for this connection: DPD
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, Starting P1 rekey timer: 24480 seconds.
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE RECEIVED Message (msgid=4203010f) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + KE (4) + ID (5) + ID (5) + NOTIFY (11) + NONE (0) total length : 320
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing SA payload
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing nonce payload
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing ke payload
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing ISA_KE for PFS in phase 2
7.1.0.2
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Received remote Proxy Host data in ID Payload:  Address 7.1.0.2, Protocol 0, Port 0
7.0.0.2
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Received local Proxy Host data in ID Payload:  Address 7.0.0.2, Protocol 0, Port 0
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing notify payload
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, QM IsRekeyed old sa not found by addr
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Static Crypto Map check, map DYNMAP, seq = 10 is a successful match
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, IKE Remote Peer configured for crypto map: DYNMAP
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, processing IPSec SA payload
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, All IPSec SA proposals found unacceptable!
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, sending notify message
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing blank hash payload
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing ipsec notify payload for msg id 4203010f
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing qm hash payload
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=5dc3acae) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, QM FSM error (P2 struct &0x00007fff9e5d3850, mess id 0x4203010f)!
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKE QM Responder FSM error history (struct &0x00007fff9e5d3850)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, sending delete/delete with reason message
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Removing peer from correlator table failed, no match!
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKE SA MM:c8ea33d7 rcv'd Terminate: state MM_ACTIVE  flags 0x0001c042, refcnt 1, tuncnt 0
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, IKE SA MM:c8ea33d7 terminating:  flags 0x0101c002, refcnt 0, tuncnt 0
Mar 02 12:03:23 [IKEv1 DEBUG]Group = DefaultRAGroup, IP = 7.1.0.2, constructing IKE delete payload
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, IKE_DECODE SENDING Message (msgid=b984f46a) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Mar 02 12:03:23 [IKEv1]Group = DefaultRAGroup, IP = 7.1.0.2, Session is being torn down. Reason: Phase 2 Mismatch
Mar 02 12:03:23 [IKEv1]Ignoring msg to mark SA with dsID 1900544 dead because SA deleted
Mar 02 12:03:23 [IKEv1]IP = 7.1.0.2, Received encrypted packet with no matching SA, dropping
Ken
Ken
It appears from the output that it is using the wrong group to try and connect.
The DefaultRAGroup is for remote access VPNs not L2L VPNs.
Because your other end is dynamic you cannot set up an explicit tunnel-group for the remote ASA but I was hoping if you added that command to the DefaultL2LGroup it would use that group.
I'm not sure currently why it is using the wrong group.
Let me have a dig around.
Jon
Jon
Same key for all authentications.
Ken
Ken
This may be the issue.
From what I understand when the connection is first made because the remote end is dynamic your ASA doesn't know whether this is a remote access VPN or a L2L VPN.
So it defaults to the DefaultRAGroup and if you are using the same key it will authenticate.
I may be wrong but could you try using a different key for the L2L VPN and then running the debug again to see if it is then trying the DefaultL2LGroup.
Jon
Jon,
I have disabled the PFS enable on both ASA's and now the tunnel is up. However not passing traffic. I will review the firewall configuration to see if I can get ping across the tunnel.
Ken
Create
Recognize Your Peers
Polls
Which of these topics should we host an event in the Community?
Top Choice: pxGrid (35%)
Content for Community-Ad
