ISDN connection problem
magalicadet
I've read all the forum messages about my problem someone have the same problem but nobody answer the good answer :-)
Tickets have been open from my Cisco contract at TAC services but answers are allways the same : "give me the debug ..."
I'll give you all the elements in this forum and hope someone could help me.
I just want my ISDN connection going up
THE PROBLEM
SDSL-878#isdn test call interface bri 0 0170131555
SDSL-878#
*Mar 3 18:53:44.163: ISDN BR0 EVENT: UserIdle: callid 0x8001 received ISDN_CALL (0x0)
*Mar 3 18:53:44.163: ISDN BR0 **ERROR**: process_bri_call: Outgoing call id 0x8001 blocked
*Mar 3 18:53:44.163: ISDN BR0 **ERROR**: UserIdle: process_bri_call failed on call to 0170131555
*Mar 3 18:53:45.083: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=99 nr=0
*Mar 3 18:53:45.087: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=99 nr=0
*Mar 3 18:53:45.087: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=99 nr=0
*Mar 3 18:53:45.099: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=99 nr=0
*Mar 3 18:53:55.099: ISDN BR0 Q921: User TX -> RRp sapi=0 tei=99 nr=0
*Mar 3 18:53:55.103: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=99 nr=0
*Mar 3 18:53:55.103: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=99 nr=0
*Mar 3 18:53:55.127: ISDN BR0 Q921: User RX <- RRf sapi=0 tei=99 nr=0
*Mar 3 18:54:05.123: ISDN BR0 Q921: User RX <- RRp sapi=0 tei=99 nr=0
*Mar 3 18:54:05.123: ISDN BR0 Q921: User TX -> RRf sapi=0 tei=99 nr=0
*Mar 3 18:54:14.163: ISDN BR0 EVENT: UserIdle: callid 0x8001 received ISDN_HANGUP (0x1)
*Mar 3 18:54:14.163: ISDN BR0 EVENT: isdn_hangup: Hangup call to call id 0x8001 ces = 1
*Mar 3 18:54:14.163: ISDN BR0 CC: CCBRI_Go: source id 0x500, state 0, call id 0x0, event 0x5
*Mar 3 18:54:14.163: ISDN BR0 **ERROR**: CCBRI_Go: NO CCB Src->HOST call id 0x8001, event 0x5 ces 1
*Mar 3 18:54:14.163: ISDN BR0 EVENT: process_rxstate: ces/callid 1/0x8001 calltype 1 HOST_QUERY_RESPONSE
My router : Cisco 878
My IOS : c870-adventerprisek9-mz.124-9.T.bin
Here is another debug :
SDSL-878#sh isdn status
Global ISDN Switchtype = vn3
ISDN BRI0 interface
dsl 0, interface ISDN Switchtype = vn3
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 99, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80000003
Total Allocated ISDN CCBs = 0
Thanks for your help !
Hi, thank you for your answer but the Senior engineers confirm that 878 doesn't allow callout from ISDN interface. It only allow the callin for management.
I need to change my 878 for a 1803 ;-)
Thank you for your help.
