Lan to Lan Connection between VPN 3030 and PIX Firewall
VesoTeam
i have to establish a vpn tunnel between a vpn 3030 Concentrator and a PIX Firewall. There is a porblem between both components bulding up the tunnel. When trying to build it up i get the following entry in the log file of the vpn concentrator.
IKE Initiator: New Phase 1, Intf 2, IKE Peer xx.x.xxx.xx
local Proxy Address xx.xx.0.0, remote Proxy Address xx.xx.yy.0,
SA (L2L: xxx)
Does anybody know what the problem could be?! I have another tunnel between the concentrator and a pix with the same configuration. Only the network lists are different.
Thanks a lot.
Christian
mike-greene
Level 4
Level 4
Can you debug on the pix and post that information...
debug crypto ipsec
debug crypto isakmp
