cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
18
Respuestas
Need help with site to site VPN on ASA 5505
ruben.ortega
Both sites have ASA5505 running version 8.2 (5)
I am very new to Cisco so please be patient with me
I used the site to site VPN wizard which seemed very straight forward and easy. I even watched a tutorial on youtube. I have a solid VPN connection light on both devices however I cannot ping from one side of the tunnel to the other.
I notice in the firewall dashboard under Top 10 Protected Servers under SYN Attack:
Server IP:Port (my VOIP srever)
Source IP (my IP phone)
  • VPN
18 RESPUESTAS 18
bmurray
Can you send the configuration from both devices?
I sent you the config's
I have sent the changed configs to you.
Okay...So I was able to make the change in the config (removed
nat (outside) 0 access-list outside_nat0_outbound)
After doing that I went to ASDM > Monitoring > VPN and set the filter to IPsec site-to-site and the session no longer shows up.
I deleted the VPN on both sides and recreated it using the wizard. I still can't see it in the VPN sessions under monitoring
Did you change the access lists for nat and crypto as in the file I sent you?
I made changes to site B as per your suggestion. I used restore in the ASDM. Then I did a backup again to make sure the config was correct and it came back with something totally different. I sent you the files if you wouldn't mind taking a look.
I did not touch site A yet.
Like I said I am very new to Cisc o so please bear with me if I am doing something wrong here and thank you very much for your assistance so far!
I made the changes you sent me to the startup and running config as according to what you sent me. When I restore to the device it drops the line.
Before restore:
global (outside) 1 interface
nat 0 (inside) acceess-list outside_nat0_outbound
nat (inside) 1 192.168.1.0 255.255.255.0
After restore:
nat (inside) 1 192.168.2.0 255.255.255.0
I am not sure what I am doing wrong
You say that your L2L VPN connection was originally UP by judging the lights on the front panel of the ASAs
Taking that into account it would seem that you are missing some other configurations if traffic isnt passing through it completely
  • NAT0 isnt configured or you havent configured some other NAT correctly
  • Since you are testing with ICMP, you havent enabled "inspect icmp" to automatically allow the Echo-reply messages through the ASA
    • inspect "icmp" is disabled by default on ASA
  • You perhaps lack some ACL rule
If you want other to check your situation it would be best to post the configurations here (and remove any sensitive information that you dont want to disclose)
If the problem is only related to ICMP not going through, the reason might even be as simple as needing to add the following configuraiton
policy-map global_policy
class inspection_default
  inspect icmp
First 2 lines are just to move to the right configuration mode on the ASA. The "inspect icmp" is the actual configuration change.
If you only use ASDM its also possible to use the CLI on the ASDM interface and drop CLI format configurations to the ASA.
Tools -> Command Line Interface
Also you would have to choose the "Multiple Line" option
- Jouni
Thank you for your response and pointers.
I will post up Site A and Site B configs in a a little while!
Site A WAN address has been changed to 111.111.111.111
Site B WAN address have been changed to 222.222.222.222
SITE A CONFIG:
: Saved
: Written by enable_15 at 19:27:35.161 UTC Wed Dec 26 2012
ASA Version 8.2(5)
hostname ciscoasa
enable password 4OyzEsAocelbS8Zt encrypted
passwd M0tRZCzV9puBYIHK encrypted
names
name 192.168.2.0 Outside
name 111.111.111.111 Site-B-Firewall
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 111.111.111.111 255.255.255.252
interface Vlan5
no nameif
security-level 50
no ip address
banner login PROPERTY OF XXXXXXX. UNAUTHORIZED ACCESS IS PROHIBITED!
ftp mode passive
access-list outside_access_in extended permit tcp any 111.111.111.111 255.255.255.255 eq 3389
access-list outside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 Outside 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
ip verify reverse-path interface inside
ip verify reverse-path interface outside
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
icmp permit any outside
no asdm history enable
arp timeout 14400
static (inside,outside) tcp interface 3389 192.168.1.10 3389 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 111.111.111.111 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no sysopt connection permit-vpn
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 222.222.222.222
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd address 192.168.1.5-192.168.1.132 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection scanning-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy DfltGrpPolicy attributes
tunnel-group 222.222.222.222 type ipsec-l2l
tunnel-group 222.222.222.222 ipsec-attributes
pre-shared-key *
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:d1c6d09621699c50ea664b70dd2a6067
SITE B CONFIG:
: Saved
: Written by enable_15 at 15:34:40.170 HST Wed Jan 2 2013
ASA Version 8.2(5)
hostname ciscoasb
names
name 192.168.1.0 Waipahu description LAN
!                                        ****SEEMS LIKE I MIGHT BE MISSING SITE A WAN HERE?****
interface Vlan1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 222.222.222.222 255.255.255.0
ftp mode passive
clock timezone HST -10
access-list outside_access_in extended permit tcp any host 222.222.222.222 eq 3389
access-list inside_cryptomap extended permit ip 192.168.2.0 255.255.255.0 interface outside
access-list outside_1_cryptomap extended permit ip 192.168.2.0 255.255.255.0 Waipahu 255.255.255.0
access-list outside_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 Waipahu 255.255.255.0
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
static (inside,outside) tcp interface 3389 192.168.2.10 3389 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 222.222.222.222 1
http server enable
http 192.168.2.0 255.255.255.0 inside
crypto map outside_map 1 set peer 111.111.111.111
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.2.100-192.168.2.150 inside
dhcpd enable inside
webvpn
tunnel-group 111.111.111.111 type ipsec-l2l
tunnel-group 111.111.111.111 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
Cryptochecksum:1cae1f9177a6933ce1946e19dd94ffcf
Here are the things I notice in the configuration.
Site A
I'm not sure if you have just copy/pasted wrong as the configuration contains the following line
It should be
nat (inside) 0 access-list outside_nat0_outbound
Site B
This sites configurations have some lackings and also differ when it comes to L2L VPN settings
  • First you need the NAT0 configuration added by using the ACL already existing on the ASA
access-list outside_nat0_outbound extended permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
Also the L2L VPN Phase2 parameter is different compared to Site A
  • Site A = crypto map outside_map 1 set pfs group1
  • Site B = crypto map outside_map 1 set pfs ( = when not showing any "group" it actually means "group2" is used)
So you would need to remove the setting on Site A and configure it again
  • no crypto map outside_map 1 set pfs group1
  • crypto map outside_map 1 set pfs group2
After you have changed the above configuration try the connections again.
Also make sure you add the following on both Sites ASA firewalls
  inspect icmp
If you dont add the "inspect icmp" command the ICMP Echo Replys wont get through the ASA firewalls.
EDIT: Dont worry about the Site B "name" configuration. It doesnt actually do anything. Its only function is to name IPs or Networks to a certain name that will show in the configuration instead of the IP or Networks
- Jouni
Okay I made changes. Would you mind looking at these configs to see if I it all looks correct? I plan on going out to the sites on Monday to install.
*edit removed so only latest shows
Site B
