PRI serial link problem
trinawong
Beginner
Beginner
Hi All,
Please advice why PRI serial link shows 'up down', but still can observe active ISDN call and E1 controller status is fine.
Serial3/0:14 unassigned YES unset down down
Serial3/0:15 unassigned YES NVRAM up down
R1#sh isdn a
ISDN ACTIVE CALLS
Call Calling Called Remote Seconds Seconds Seconds Charges
Type Number Number Name Used Left Idle Units/Currency
In 1111111111 5000 4444 Unavail -
In 1111111112 5000 1117 Unavail -
In 1111111113 5000 681 Unavail -
In 1111111114 5000 27 Unavail -
spremkumar
Engager
Engager
hi
Can you post the configuration of your box as well the o/p of show controllers ?
regds
interface Serial3/0:15
no ip address
ip access-group 157 in
encapsulation ppp
dialer rotary-group 1
dialer-group 1
isdn switch-type primary-net5
isdn incoming-voice modem 64
no fair-queue
no cdp enable
interface Group-Async1
ip unnumbered Loopback0
ip access-group 100 in
encapsulation ppp
dialer in-band
dialer idle-timeout 3600
dialer-group 1
async dynamic routing
async mode interactive
peer default ip address pool pool0
ppp authentication chap pap
group-range 1 30
interface Dialer1
ip access-group 160 in
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer-group 1
no fair-queue
no cdp enable
ppp authentication pap chap
ppp multilink
R1#sh contr e1
E1 3/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
Data in current interval (57 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
