Problem using WIC1ADSL Card in 2610 Router
during the bootup of my Router I receive the following Error Message:
00:00:07: %PQUICC-1-UNKNOWN_WIC: PQUICC(0), WIC card has an unknown ID of 0x2E
I use the following IOS Version:
IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(27)
Can anyone suggest me if it is a Problem with the IOS Version or Featureset or if the Hardware is damaged?
When it is the IOS Version or Featureset, which Version/Featureset do I need?
Best Regards
Marcos
Hello Marcos,
try IOS software release IP Plus 12.2(13)T (e.g. c2600-is-mz.122-13.T16.bin), this should recognize the WIC.
You can also check the following document for the requirements:
Cisco 1700/2600/3600/3700 Series 1-Port ADSL WICs
http://www.cisco.com/en/US/partner/products/hw/routers/ps221/products_data_sheet09186a0080088713.html
HTH,
GP
now the Interface is running ;-)
But the status still remains down/down after connecting it to the splitter. I used "debug atm event" and I can see only the following:
*snip*
router-2610#term mon
router-2610#debug atm ev
ATM events debugging is on
router-2610#
*Mar 1 00:39:59.528: DSL(ATM0/0): 14: Modem state = 0x8
router-2610#
*Mar 1 00:40:02.029: DSL(ATM0/0): 15: Modem state = 0x8
router-2610#
*Mar 1 00:40:04.529: DSL(ATM0/0): 16: Modem state = 0x8
router-2610#
*Mar 1 00:40:07.029: DSL(ATM0/0): 17: Modem state = 0x8
router-2610#
*Mar 1 00:40:09.529: DSL(ATM0/0): 18: Modem state = 0x8
router-2610#
*Mar 1 00:40:12.029: DSL(ATM0/0): 19: Modem state = 0x8
router-2610#
*Mar 1 00:40:14.529: DSL(ATM0/0): 20: Modem state = 0x8
router-2610#
*Mar 1 00:40:17.029: DSL(ATM0/0): Could not establish connection event=1
*Mar 1 00:40:17.029: DSL(ATM0/0): Sent command 0x4
*Mar 1 00:40:17.029: DSL(ATM0/0): Send ADSL_OPEN command.
*Mar 1 00:40:17.029: DSL(ATM0/0): Using subfunction 0x15
*Mar 1 00:40:17.029: DSL(ATM0/0): Sent command 0x3
*Mar 1 00:40:17.061: DSL(ATM0/0): Received response: 0x25
*Mar 1 00:40:17.061: DSL(ATM0/0): Unexpected response 0x25
*Mar 1 00:40:17.061: DSL(ATM0/0): Send ADSL_OPEN command.
*Mar 1 00:40:17.061: DSL(ATM0/0): Using subfunction 0x15
*Mar 1 00:40:17.061: DSL(ATM0/0): Sent command 0x3
router-2610#
*Mar 1 00:40:19.565: DSL(ATM0/0): 1: Modem state = 0x8
router-2610#no debug
*Mar 1 00:40:22.065: DSL(ATM0/0): 2: Modem state = 0x8
router-2610#no debug all
*Mar 1 00:40:24.566: DSL(ATM0/0): 3: Modem state = 0x8
All possible debugging has been turned off
router-2610#
*snip*
Can anyone help, please?
Marcos
I had done some more research... Now I have a guess, what the Problem could be... I use ADSL over ISDN. The ADSL Card (WIC1ADSL) is connected to the splitter. I think I should use one WIC-1ADSL-I-DG Card, right?
Is it possible to configure the WIC1ADSL like an WIC-1ADSL-I-DG ?
Marcos
can anyone help me?
Marcos
