Problem with Cisco IOS EZVPN after the clients disconnect.
Francis Garcia
Hi folks,
Actually I have just setup a vpn, everything is working fine except when the clients disconnect the VPN client session. What happens is that when I issue ¨show ip route¨ the static route pointing to the client is still there,  even if I issue clear ip route and the prefix, the route doesn't get deleted. The only way that I can clear the static route is reloading the router.
What I mean is this.
S       10.205.0.3/32 [1/0] via X.X.X.X
S       10.205.0.2/32 [1/0] via X.X.X.X
S       10.205.0.1/32 [1/0] via X.X.X.X
It was tree hours after I disconnect the VPN session, and the static routers were still there.
If you got any sugestion will be welcome.
Yudong Wu
Level 7
Level 7
It souds like a bug.
What version are you running?
