Problem with GRE
josedelpino
Hi all
Basically I have a vpn between a branch and central, it works fine but occasionally the GRE tunnels are turned off and stops working vpn.
With reset solved, but the problem still occurs occasionally from time to time
By the way .. is not a problem of saturation because little traffic passing through the router
Any help will be welcome
andrew.prince
Level 10
Level 10
configure the gre tunnel with a keepalive.
andrew.prince
Level 10
Level 10
