09-22-2003 11:22 PM - edited 02-21-2020 12:47 PM
I have installed the Cisco VPN client 4.0.2(D). I am able to authenticate with our VPN Concentrators and the client says that a secure channel has been established. However, directly after that the client disconnects the session.
The following is the output from the log:
Cisco Systems VPN Client Version 4.0.2 (D)
Copyright (C) 1998-2003 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.0.2195
1 09:15:40.090 09/23/03 Sev=Warning/2 IKE/0xE3000099
Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:938)
2 09:15:40.090 09/23/03 Sev=Warning/2 IKE/0xE30000A5
Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2199)
Any help would be appreciated!
Harald
09-29-2003 06:50 AM
You seem to be facing the same issue as that described in CSCeb41256. As per the bug, the only way to recover after running into this issue is to reboot the system.
10-11-2003 05:55 PM
maybe your vpn client software got corrupted try to re-install the vpn client again to see if that help or not.
