09-27-2017 02:16 AM - edited 03-12-2019 04:34 AM
Hi there,
I seem to be experiencing a problem installing/uninstalling Anyconnect. While trying to uninstall 4.4.03034, it still asks for 3.1.03103 (even pointing to the MSI doesn't work out). Same problem with the NAM module...
Thanks!
/dimi
09-27-2017 05:48 AM
Try installing the Anyconnect VPN 4.4 module and uninstalling it again. Usually when you remove the Anyconnect VPN (Core) module, it asks you if you want to remove all components. This should then remove both VPN and NAM together.
09-27-2017 05:59 AM
Thanks Rahul for your reply!
I've already tried to uninstall everything / the DART and the Core module (that would be the client) and yes, everything seems to be "gone". After that : even tried to first install the v3.1.03103 client first, update it to 4.4.03034 and tried the NAM after that (also v 4.4.03034) - I always get a message that it needs 3.1.03103.
Had a look with ProcMon but no clues there...
09-27-2017 06:04 AM
09-27-2017 06:36 AM
09-28-2017 11:41 AM
That's odd. Can you run a complete DART bundle after the install? Install errors usually show up in a log file under the NAM folder. If this is seen on all machines, opening a TAC case might be more helpful.
