Problems with routing over a VPN Connection (ASA5505)
fvalpondi
Dear all,
I have to connect two remote sites using an IPSec Tunnel (EasyVPN). The devices to be used are two Cisco ASA 5505.
They have already been connected to the internet and configured and they can see and ping each other via the “outside” interface. The inside interfaces on both sides have a private address range 192.168.160.0/24 and 192.168.128.0/24.
Before connecting the to the internet I configured them connected to a 2921 Router that simulated the Internet (both interfaces had the adresses of the real gateways). In my test configuration the tunnel was established (checked via show isakmp sa) and two computers connected in the inside interfaces of each ASA could ping each other.
Test Config: *PC*-------*in*ASA*out*-------*2921*----------*out*ASA*in*---------*PC*
The problems came when I connected the ASA devices to the internet. The tunnel is established but I cannot ping devices in the inside interface of the other ASA. Even though the routing table has the correct values.
Real Config: *PC*-------*in*ASA*out*-------*Internet*----------*out*ASA*in*---------*PC*
I am not an expert with the ASA, but as far as I know there shouldn't be a problem with the inside interfaces having a private address, since the whole information is sent through the tunnel, right?
Thanks a lot for your help!
Fabio
23 Replies 23
Maybe a stupid question, but are you sure you are inspecting icmp?
Otherwise write "fixup protocol icmp".
thanks for your answer. On both devices I configured icmp as follows:
icmp permit any inside
icmp permit any outside
And the policy map is as follows:
policy-map global_policy
 class inspection_default
  inspect dns preset_dns_map
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
This icmp inspection has something to do? What is puzzling me is the fact that my test configuration with the 2911 router simulating internet works and once I connect it to the real internet it doesn't.
thanks again!
Fabio
Hi Fabio,
Can you provide the output of below :
Show run nat
sh route
show cry isa sa
show cry ips sa
Altaf
at the moment I only have access to one of the ASAs (the one acting as server). For security reasons I have changed the public IPs.
Find also attached a schema of the network (at the moment there are no devices connected in the 192.168.160.0 network). When I tested it, there were.
show run nat
ASA# sh run nat
nat (inside) 0 access-list no-nat
nat (inside) 1 0.0.0.0 0.0.0.0
ASA#
sh route
ASA# sh route
Gateway of last resort is 192.168.128.1 to network 0.0.0.0
S    1.1.1.0 255.255.255.224 [1/0] via 2.2.2.1, outside
C    192.168.128.0 255.255.255.0 is directly connected, inside
S    192.168.160.0 255.255.255.0 [1/0] via 2.2.2.1, outside
C    2.2.2.0 255.255.255.224 is directly connected, outside
S*   0.0.0.0 0.0.0.0 [1/0] via 192.168.128.1, inside
show cry isa sa
ASA# sh cry isa sa
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 1.1.1.2
    Type    : user            Role    : responder
    Rekey   : no              State   : AM_ACTIVE
show cry ips sa
BB-ERL# sh cry ips sa
interface: outside
    Crypto map tag: dyn-bb-map, seq num: 5, local addr: 146.254.60.228
      local ident (addr/mask/prot/port): (2.2.2.2/255.255.255.255/0/0)
      remote ident (addr/mask/prot/port): (1.1.1.2/255.255.255.255/0/0)
      current_peer: 1.1.1.2, username: user
      dynamic allocated peer ip: 0.0.0.0
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 2.2.2.2, remote crypto endpt.: 1.1.1.2
      path mtu 1500, ipsec overhead 74, media mtu 1500
      current outbound spi: 5AAC68DB
      current inbound spi : EF3D1228
    inbound esp sas:
      spi: 0xEF3D1228 (4013756968)
         transform: esp-aes-256 esp-sha-hmac no compression
         in use settings ={RA, Tunnel, }
         slot: 0, conn_id: 32768, crypto-map: dyn-bb-map
         sa timing: remaining key lifetime (sec): 27308
         IV size: 16 bytes
         replay detection support: Y
         Anti replay bitmap:
          0x00000000 0x00000001
    outbound esp sas:
      spi: 0x5AAC68DB (1521248475)
         IV size: 16 bytes
         Anti replay bitmap:
    Crypto map tag: dyn-bb-map, seq num: 5, local addr: 2.2.2.2
      local ident (addr/mask/prot/port): (192.168.128.0/255.255.255.0/0/0)
      current outbound spi: B66B6785
      current inbound spi : 8ADC7777
    inbound esp sas:
      spi: 0x8ADC7777 (2329704311)
         sa timing: remaining key lifetime (sec): 27309
         IV size: 16 bytes
         Anti replay bitmap:
    outbound esp sas:
      spi: 0xB66B6785 (3060492165)
         sa timing: remaining key lifetime (sec): 27307
         IV size: 16 bytes
         Anti replay bitmap:
Thanks a lot!!
Fabio
Can you check the NAT 0, are you sure you are exempting the traffic, for troubleshooting, please get the packet tracer output. we need to initiate a packet tracer from the inside interface:
something like this:
packet input inside icmp 192.168.128.5 8 0 1.1.1.2 det
you will see where the packet is dropping , if it doesn't then flow should be allowed and goes through VPN.
if you have difficulties, please paste the above output here for analyse.
-Altaf
thanks for your answer. I don't have access to the devices anymore. I won't be able to do this until monday.
However, in my test scenario, which is the same as the real one but simulating the internet connection using a Cisco2921, I could ping and communicate  from both ASA's "inside sides" (I was able to establish a remote desktop session as well!!)
best regards,
Fabio
One more thing is, if you trying to ping inside interface through the VPN(in non-working one), then please add:
Management-access inside
if not then the packet tracer output will clearly tell you where could be the issue is.
-Altaf
according to the outputs i copied here, the traffic between both inside networks should be routed through the VPN, right?
In my test scenario it worked flawlessly. It is with the "internet" connection where I have all the problems.
Best regards,
Fabio
Once you send a ping to the destination from the source 192.168.128.X, observe the output of "sho cry ips sa" and see the counters of encaps/decaps. if the encap counter is not incrementing then then traffic isn't going through the tunnel.
In this case packet tracer command which I highlighted will help.
-Altaf
Dear Altaf,
thanks for your message. I did as you requested (from the device 1.1.1.2). When I ping from 192.168.160.x to 192.168.128.x the ENCAPS are incremented, but not the DECAPS (Ping failed). When I ping from 1.1.1.2 to 2.2.2.2 both ENCAPS and DECAPS are incremented (Ping successfull).
I did the packet tracer tests you told me and here is what I got. It looks like the return path is not allowed through the ACL. Am I right?
ASA# packet-tracer input inside icmp 192.168.160.12 8 0 192.168.128.1
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   0.0.0.0         0.0.0.0         outside
Phase: 2
Type: ACCESS-LIST
Subtype: aaa-user
Result: ALLOW
Config:
Phase: 3
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 4
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 5
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
  match ip inside any outside 192.168.128.0 255.255.255.0
    NAT exempt
    translate_hits = 12, untranslate_hits = 0
Phase: 6
Type: NAT
Subtype:
Result: ALLOW
Config:
  match ip inside any outside any
    dynamic translation to pool 1 (1.1.1.2 [Interface PAT])
    translate_hits = 49, untranslate_hits = 80
Phase: 7
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
  match ip inside any inside any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 0, untranslate_hits = 0
Phase: 8
Type: VPN
Subtype: encrypt
Result: ALLOW
Config:
Phase: 9
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 636, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
ASA#
ASA# packet-tracer input outside icmp 192.168.128.1 8 0 192.168.160.12
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.160.0     255.255.255.0   inside
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: outside
input-status: up
output-interface: inside
output-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
As per the output, we see ACL, NAT and VPN is correct. It is correctly flowing through the VPN.
Could you confirm if you are using any ACL on the dynamic map on the ezvpn server ?
-Altaf
Hi Altaf,
this is the ACL config in the server:
ASA-SRV# sh run
: Saved
ASA Version 8.2(5)
hostname ASA-SRV
enable password ************* encrypted
passwd *********** encrypted
names
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 192.168.128.2 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 2.2.2.2 255.255.255.224
ftp mode passive
access-list no-nat extended permit ip 192.168.128.0 255.255.255.0 192.168.160.0 255.255.255.0
access-list bb-traffic extended permit ip 192.168.128.0 255.255.255.0 192.168.160.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
route inside 0.0.0.0 0.0.0.0 192.168.128.1 1
route outside 192.168.160.0 255.255.255.0 2.2.2.1 1
route outside 1.1.1.0 255.255.255.224 2.2.2.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.128.0 255.255.224.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set bb-set esp-aes-256 esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dyn-bb-map 5 set transform-set bb-set
crypto map bb-map 60 ipsec-isakmp dynamic dyn-bb-map
crypto map bb-map interface outside
crypto isakmp enable outside
crypto isakmp policy 1
 authentication pre-share
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.128.100-192.168.128.110 inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy bbgroup internal
group-policy bbgroup attributes
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value bb-traffic
 nem enable
username user password ********* encrypted
tunnel-group bb-tunnel type remote-access
tunnel-group bb-tunnel general-attributes
 default-group-policy bbgroup
tunnel-group bb-tunnel ipsec-attributes
 pre-shared-key **********
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
Could you remove the split tunnel from the configuration from the group-policy, bounce the tunnel and reconnect and check?
Hopefully this works.
Altaf
Hi Altaf,
it is enough if I issue the following commands?
 no split-tunnel-policy tunnelspecified
 no split-tunnel-network-list value bb-traffic
Or anything else has to be done to remove the split tunnel?
Best regards,
Fabio
