Problems with VPN client and Split Tunneling on 3030
d.jursik
I got one problem with Split Tunneling and client 3.5.2 on 3030 with 3.6.7.
I'm using split tunneling for about 20 networks. The client builds up tunnel for 3030 one network but when he tries to build a tunnel for another network i get:
99 19:04:41.750 06/04/03 Sev=Info/5 IKE/0x63000055
Received a key request from Driver for IP address 1.1.1.1, GW IP = x.x.x.x
100 19:04:41.750 06/04/03 Sev=Warning/3 IKE/0xE3000002
Function InitProxies failed with an error code of 0x00000000(INITIATE:284)
101 19:04:41.750 06/04/03 Sev=Info/5 IKE/0x63000018
Deleting IPsec SA: (OUTBOUND SPI = B85D8F0 INBOUND SPI = 156A35F)
And after that the client disconnects the VPN session.
Do somebody have an idea ?
Daniel
drolemc
Level 6
Level 6
If you are using XP, you should have a look at Bug CSCdz75809. Though the version for which the bug is reported is different, the problem described seems to be the same as that described by you. Best of Luck.
