Remote Power Control
limleeheng
Does anyone know a goof remote power control hardware so that I can do a remote power reboot or power on/off over telnet or web interface?
Thank you.
Ron
paddyxdoyle
Level 6
Level 6
You can use SNMP to force a device to reload.
Have a look here for the details
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_q_and_a_item09186a00800c263d.shtml#qa4
If you are going to deploy this method on your devices i would recommend also using access-lists within your SNMP config so that your devices will only accept SNMP read/writes from specific hosts.
Paddy
If you want an enterprise class solution then take a look at this.
http://www.servertech.com/
You even do environmental monitoring and a few other cool things.
Hope this helps.
Please remember to rate all replies
