Restrict AnyConnect FlexVPN Connectivity with CSR1kv in multi VRF scenario if IKEid (key) is leaked
manoghos
Hi Experts,
I need help in configuring an ikev2 profile for VRF to restrict other VRF users.
AnyConnect Client 4.5 is using FlexVPN using AnyConnect-EAP authentication with an IKE ID for matching remote key identity.
Also, we are using a local AAA database.( No Radius/TACACS).
In case I got the IKE ID of any other tenant and using that in my AnyConnect profile I can connect to another tenant network.
I hope this can be restricted using name-mangler option in aaa authorization group/user in ikev2 profile but found limited examples for implementing it with local-AAA.
Please find the configuration snapshot.
18 Replies 18
Hi RJI,
I have next level issue posted here: https://community.cisco.com/t5/nso-developer-hub-discussions/cisco-ios-ned-doesn-t-support-ikev2-name-mangler-eap-option/m-p/3821903#M3519
any possibility to get the same result using mangler option of 'dn' /'email'/'fqdn' instead of using 'eap'.
crypto ikev2 name-mangler mangler1
eap suffix delimiter @
Do the client computers also have user certificates? You could use double authentication (eap + certificate) and authorize using the certificate, using the name-managler extracting a value from the DN:- state, OU etc.
No, Clients are not having certificates at time of authetication. only the VRF trustpoint are having certificates for fqdn domain check.
Hi RJI,
Do you have any idea on authorization prohibition/restriction? Can we restrict based on authorization by creating any user group per VRF in local AAA
