Ridiculous ASA5505 OSX Problem
brookkaren
So this is wild.  I took an ASA5505 out of the box and upgrade the firmware to 8.4.(2)8.  I used the VPN wizard to build an IPSEC remote access VPN.  I test with a win7 full cisco client and it works (test from a virtual machine using a wireless connection on the host), i test with my iphone running IOS 5 .0.1 and it works.  I test with a laptop running snow leopard 10.7.2 and the same wireless connection from above and it cannot negotiate.  If i plug directly into the ASA5505 and try to VPN it connects instantly.
Below is the config, i'm completely baffled here.
Result of the command: "sh run"
: Saved
ASA Version 8.4(2)8
hostname ciscoasa
enable password QSM0mlnK8RBz4RL9 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 192.168.150.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_10.1.2.0_25
subnet 10.1.2.0 255.255.255.128
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
ip local pool kay 10.1.2.1-10.1.2.100 mask 255.255.255.255
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.1.2.0_25 NETWORK_OBJ_10.1.2.0_25 no-proxy-arp route-lookup
nat (inside,outside) dynamic interface
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.150.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.150.5-192.168.150.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy kay internal
group-policy kay attributes
dns-server value 192.168.1.1
vpn-tunnel-protocol ikev1
username test password P4ttSyrm33SV8TYp encrypted
tunnel-group kay type remote-access
tunnel-group kay general-attributes
address-pool kay
default-group-policy kay
tunnel-group kay ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:9aa371b81e66638060a3ecff943a3d02
: end
Herbert Baerten
Hi brookkaren
I agree this seems weird but it's hard to say what's wrong without more information.
I would suggest to start with enabling these debugs on the ASA:
debug crypto ipsec  10
debug crypto ikev1  10
debug crypto ike-common 10
as well as checking the client logs (see the "log" tab, you can increase the logging level in the "logging" menu).
hth
Herbert
