ROUTE Based VTI on FMC incoming traffic dropped
we have a number of Sonicwalls and fortigate at our other sites and also connections to Azure and we had been waiting on the route based availability for the FTD to be released to convert to using route based. Now it has we have done the upgrade and now looking to change the tunnels to route based. we attempted this to both a sonicwall and the fortigate and the all went well tunnel is up ACLs created and static route to the sites through the VTI interfaces all good except i can get traffic out to the other end and back but any traffic coming in seems to get dropped we can see this with the packet tracer have we missed anything as i say there is a route and a outgoing and incoming ACL. Also when we created the interfaces we created a new security zone for them  for the ACLs to applied against.
here is partial output
7 Replies 7
Hi @billystevenson24098
What did you configure in your Access Control Policies (ACP) for this VPN traffic?
the are disabled the now but when they were enabled we could get to ping to remote sites and get reply but any pings coming in timed out and we could see the traffic on the packet capture and it was getting dropped tried it with 2 SW and 1 fortigate to check the settings but all came back the same
Right ok, so the packet-tracer screenshot is from when the ACP rules are disabled?
So the packets are dropped on your end? Is your ACP rules correct for the src/dst networks on traffic initiated from the remote end?
Provide the logs/packet capture of when the traffic is dropped.
Have you checked NAT on both ends?
If those networks src/dst are correct and traffic is not hitting those rules and hitting the default deny, then those zones could be incorrect? which would explain why the traffic does not match those rules. Remove the src/dst zones temporarily.
Why do those rules say disabled, I assume they are enabled?
they were but that tunnel is now down as it was one of the testing ones so just disabled them will trying to find more info
so set the zones as any - any
