Strange vpn problem two ASA's stuck on mm2
Marcin chojna
We have problems to establish vpn tunnel between two ASA's the problem begun  after  we migrate site from 5520 with 8.2 to 5515-X with 9.1(1).
On  site one  we have ASA5585-SSP-10 with 8.4(3), on site two we have 5515-X with 9.1(1).
VPN on both sites are stoping on  MM2 but not always on site two it shows  sometime MM3  . Packet tracer output  on one  site looks almost the same like two site.
Also ,  we have the  same effect when we have identity  nat  like this : nat (CORE_HANDOVER,outside interface).
topology is like this :
(routed handover to ASA) L3 Switch  --- ASA one --- internet --- ASA two --- L3 Swich (routed handover to ASA)
Phase: 1
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Additional Information:
in   192.168.225.0   255.255.255.0   CORE_HANDOVER
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Config:
nat (CORE_HANDOVER,any) source static nonat-source nonat-source destination static nonat-destination nonat-destination no-proxy-arp route-lookup
NAT divert to egress interface CORE_HANDOVER
Untranslate 192.168.225.10/80 to 192.168.225.10/80
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group blok in interface outside
access-list blok extended permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 192.168.110.10/10000 to 192.168.110.10/10000
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 8
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 9
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Config:
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Config:
Phase: 11
Type: NAT
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 13
Type: VPN
Subtype: encrypt
Result: DROP
Config:
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: CORE_HANDOVER
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Phase 1 debug  site one
Jul 07 01:12:30 [IKEv1 DEBUG]IP = 3.3.3.3, IKE SA MM:38d0a9db terminating:  flags 0x01000022, refcnt 0, tuncnt 0
Jul 07 01:12:30 [IKEv1 DEBUG]IP = 3.3.3.3, sending delete/delete with reason message
Jul 07 01:12:30 [IKEv1 DEBUG]Pitcher: received a key acquire message, spi 0x0
Jul 07 01:12:30 [IKEv1]IP = 3.3.3.3, IKE Initiator: New Phase 1, Intf CORE_HANDOVER, IKE Peer 3.3.3.3  local Proxy Address 192.168.226.0, remote Proxy Address 192.168.1.0,  Crypto map (cmap)
Jul 07 01:12:30 [IKEv1 DEBUG]IP = 3.3.3.3, constructing ISAKMP SA payload
Jul 07 01:12:30 [IKEv1 DEBUG]IP = 3.3.3.3, constructing NAT-Traversal VID ver 02 payload
Jul 07 01:12:30 [IKEv1 DEBUG]IP = 3.3.3.3, constructing NAT-Traversal VID ver 03 payload
Jul 07 01:12:30 [IKEv1 DEBUG]IP = 3.3.3.3, constructing NAT-Traversal VID ver RFC payload
Jul 07 01:12:30 [IKEv1 DEBUG]IP = 3.3.3.3, constructing Fragmentation VID + extended capabilities payload
Jul 07 01:12:30 [IKEv1]IP = 3.3.3.3, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 208
Jul 07 01:12:30 [IKEv1]IP = 3.3.3.3, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jul 07 01:12:36 [IKEv1 DEBUG]Pitcher: received a key acquire message, spi 0x0
Jul 07 01:12:36 [IKEv1]IP = 3.3.3.3 Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jul 07 01:12:38 [IKEv1]IP = 3.3.3.3, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 208
Jul 07 01:12:46 [IKEv1]IP = 3.3.3.3, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 208
Jul 07 01:12:54 [IKEv1]IP = 3.3.3.3, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 208
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, IKE MM Initiator FSM error history (struct &0x00007fff2b71a990)  <state>, <event>:  MM_DONE, EV_ERROR-->MM_WAIT_MSG2, EV_RETRY-->MM_WAIT_MSG2, EV_TIMEOUT-->MM_WAIT_MSG2, NullEvent-->MM_SND_MSG1, EV_SND_MSG-->MM_SND_MSG1, EV_START_TMR-->MM_SND_MSG1, EV_RESEND_MSG-->MM_WAIT_MSG2, EV_RETRY
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, IKE SA MM:05a6d31f terminating:  flags 0x01000022, refcnt 0, tuncnt 0
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, sending delete/delete with reason message
Jul 07 01:13:02 [IKEv1 DEBUG]Pitcher: received a key acquire message, spi 0x0
Jul 07 01:13:02 [IKEv1]IP = 3.3.3.3, IKE Initiator: New Phase 1, Intf CORE_HANDOVER, IKE Peer 3.3.3.3  local Proxy Address 213.189.38.192, remote Proxy Address 192.168.0.0,  Crypto map (cmap)
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, constructing ISAKMP SA payload
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, constructing NAT-Traversal VID ver 02 payload
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, constructing NAT-Traversal VID ver 03 payload
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, constructing NAT-Traversal VID ver RFC payload
Jul 07 01:13:02 [IKEv1 DEBUG]IP = 3.3.3.3, constructing Fragmentation VID + extended capabilities payload
Jul 07 01:13:02 [IKEv1]IP = 3.3.3.3, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 208
Jul 07 01:13:02 [IKEv1]IP = 3.3.3.3, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jul 07 01:13:03 [IKEv1 DEBUG]Pitcher: received a key acquire message, spi 0x0
Jul 07 01:13:03 [IKEv1]IP = 3.3.3.3, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jul 07 01:13:10 [IKEv1]IP = 3.3.3.3, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 208
Jul 07 01:13:18 [IKEv1]IP = 3.3.3.3, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (
Debug isakmp site two
Jul 07 00:38:43 [IKEv1]IP = 4.4.4.4, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 172
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, IKE MM Initiator FSM error history (struct &0x00007ffed93eabb0)  <state>, <event>:  MM_DONE, EV_ERROR-->MM_WAIT_MSG2, EV_RETRY-->MM_WAIT_MSG2, EV_TIMEOUT-->MM_WAIT_MSG2, NullEvent-->MM_SND_MSG1, EV_SND_MSG-->MM_SND_MSG1, EV_START_TMR-->MM_SND_MSG1, EV_RESEND_MSG-->MM_WAIT_MSG2, EV_RETRY
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, IKE SA MM:3d16134c terminating:  flags 0x01000022, refcnt 0, tuncnt 0
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, sending delete/delete with reason message
Jul 07 00:38:51 [IKEv1 DEBUG]Pitcher: received a key acquire message, spi 0x0
Jul 07 00:38:51 [IKEv1]IP = 4.4.4.4, IKE Initiator: New Phase 1, Intf office, IKE Peer 4.4.4.4  local Proxy Address 192.168.200.0, remote Proxy Address 192.168.224.0,  Crypto map (cmap)
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, constructing ISAKMP SA payload
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, constructing NAT-Traversal VID ver 02 payload
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, constructing NAT-Traversal VID ver 03 payload
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, constructing NAT-Traversal VID ver RFC payload
Jul 07 00:38:51 [IKEv1 DEBUG]IP = 4.4.4.4, constructing Fragmentation VID + extended capabilities payload
Jul 07 00:38:51 [IKEv1]IP = 4.4.4.4, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 172
Jul 07 00:38:52 [IKEv1 DEBUG]Pitcher: received a key acquire message, spi 0x0
Jul 07 00:38:52 [IKEv1]IP = 4.4.4.4, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jul 07 00:38:54 [IKEv1 DEBUG]Pitcher: received a key acquire message, spi 0x0
Jul 07 00:38:54 [IKEv1]IP = 4.4.4.4, Queuing KEY-ACQUIRE messages to be processed when P1 SA is complete.
Jul 07 00:38:59 [IKEv1]IP = 4.4.4.4, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 172
Jul 07 00:39:07 [IKEv1]IP = 4.4.4.4, IKE_DECODE RESENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 172
site ONE
IKEv1 SAs:
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: 3.3.3.3
    Type    : user            Role    : initiator
    Rekey   : no              State   : MM_WAIT_MSG2
site TWO
IKEv1 SAs:
   Active SA: 1
Total IKE SA: 1
1   IKE Peer: 4.4.4.4
Nat configuration Site two (migrated one)
no arp permit-nonconnected
nat (CORE_HANDOVER,outside) source static obj-192.168.226.12 obj-11.189.38.252 dns
nat (CORE_HANDOVER,outside) source static obj-192.168.226.10 obj-11.189.38.250 dns
nat (CORE_HANDOVER,outside) source static obj-192.168.226.11 obj-11.189.38.251 dns
nat (CORE_HANDOVER,outside) source static obj-192.168.225.72 obj-11.189.38.242 dns
nat (CORE_HANDOVER,outside) source static obj-192.168.226.14 obj-11.189.38.249 dns
nat (CORE_HANDOVER,management) source static obj-192.168.251.35 obj-192.168.250.209 dns
nat (CORE_HANDOVER,outside) source static obj-192.168.226.13 obj-11.189.38.253 dns
nat (outside,DMZ-TOOL) source static obj-11.189.38.0 obj-11.189.38.0 destination static obj-11.189.38.0 obj-11.189.38.0 no-proxy-arp route-lookup
nat (DMZ-TOOL,outside) source static obj-11.189.38.0 obj-11.189.38.0 destination static obj-11.189.38.0 obj-11.189.38.0 no-proxy-arp route-lookup
nat (CORE_HANDOVER,outside) source static obj-192.168.225.10 obj-11.189.38.241 dns
object network obj-192.168.225.0
nat (CORE_HANDOVER,outside) dynamic 11.189.38.254
object network obj-192.168.249.0
object network obj-192.168.231.0
object network obj-192.168.226.0
object network obj-192.168.227.0
object network obj-192.168.228.0
object network obj-192.168.229.0
object network obj-192.168.248.0
Crypto Config
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set AES256MD5 esp-aes-256 esp-md5-hmac
crypto ipsec security-association pmtu-aging infinite
crypto map cmap 100 match address cacl
crypto map cmap 100 set peer 3.3.3.3
crypto map cmap 100 set ikev1 transform-set ESP-3DES-SHA AES256MD5
crypto map cmap interface outside
crypto ca trustpool policy
crypto ikev1 enable outside
crypto ikev1 policy 11
authentication pre-share
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 12
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
access-list cacl extended permit ip 11.189.38.192 255.255.255.192 195.182.34.0 255.255.255.0
access-list cacl extended permit ip 11.189.38.192 255.255.255.192 192.168.0.0 255.255.0.0
access-list cacl extended permit ip 192.168.224.0 255.255.224.0 192.168.200.0 255.255.255.0
access-list cacl extended permit ip 192.168.224.0 255.255.224.0 192.168.0.0 255.255.128.0
Marcin chojna
anyone?
I'm having the same issue. Endpoints that were working now are not. Find a fix?
