03-15-2006 06:56 PM
I'm looking for the pinout on the power supply that UBR904 and UBR924 cable access routers use. The adapter is $90-100 online and I already know the voltages, I just need to know which pin is which! Any help would be appreciated, thanks.
03-16-2006 05:43 AM
03-16-2006 09:40 AM
Thanks, but I've already seen those pages. The problem is, the UBR905 page shows the exact voltages and pin positions, but the UBR904 page doesn't have any details! And the UBR904 power supply is the one that's difficult to find! (It uses an 8-pin DIN connection).
I may end up having to buy one and check the corresponding voltages, and if I do, I'll be sure to post it in this forum, since I know it will be useful to someone.
