VPN connection
mweiner5641
Beginner
Beginner
Hi all. I am wondering as to why when I VPN in I can't access all of the internal servers. Is there rule that needs to be created?
rizwanr74
Rising star
Rising star
Can you make sure, that you create a nat-examption between your vpn-in dhcp-pool subnet and your inside resource's subnet.
thanks
I can hit 1 of the IP addresses in my network. From there I can ssh to any IP on my internal network. I still can't figure out why I can't directly SSH into it.
Either you are missing static-route on your Internal switch to push vpn-pool to ASA or you are missing a nat-examption between vpn-pool and inside resource's subnet.
Check this out whether these exists on your network.
thanks
Recognize Your Peers
