306
tonny_ecmyy
Beginner
VPN Connection
Here's the simple question i guess, when i connected through vpn using vpn client to the inside network of my HQ, can i see the entire network in HQ by clicking on my network places?
Thanks for helping
Tonny
1 ACCEPTED SOLUTION
Hope this helps!
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a0080194b4a.shtml
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
4 REPLIES 4
turnbull
Beginner
Hi Tonny,
The simple answer is Yes. If set up correctly, it is possible to browse netbios through a Cisco VPN client tunnel.
Cheers,
Paul.
thanks for quick reply.
I think the answer is becoming complicated when i want to know the proper way to set up it. Which one we have to configure most, the server or pix firewall/cisco router?
Tonny
Hope this helps!
Sankar Nair
Thanks for provide the useful link to troubleshoot this problem, it is very helpful, everything is fine and i'm very very happy :)
Tonny
Content for Community-Ad
