VPN problem on ASA5505 8.3 using ASDM 6.3?
firmapost
Get this error when trying to connect using Cisco VPN client 5.0.06.0160
5Aug 20 201010:06:35713257Phase 2 failure: Mismatched attribute types for class Encapsulation Mode: Rcv'd: Tunnel Cfg'd: Transport
Anyone who has any idea of this problem.
Have spent some hours without finding the problem....
manish arora
Level 6
Level 6
can you post configuration ( remove public ip and passwords ) and also output of debug crypto ipsec sa please ?
thanks
manish
b.julin
Level 3
Level 3
Check that your crypto map has a transform-set that does not have "mode transport".  You may also need the "mode transport" entry but if you have clients that have to have tunnel mode then you have to have a separate map/dynamic-map entry for them.
