AnyConnect Removal Script
jmeetze80
I have tested installing AnyConnect with Web Security using the installation script found in the AnyConnect deployment guide and successfully gotten it to work.
When I installed the client, I enabled the flags to hide the uninstall under Add/Remove Programs, and enabled the "Lockdown" flag in order to prevent users from removing the client.
In the deployment guide, there is also an uninstall script which I have attempted to test, but it just does nothing. Has anyone had success with the AnyConnectRemovalScript.cmd which is mentioned in the AnyConnect Deployement Guide? I am attaching my script in case someone out there sees something I'm missing.
JM
0 Replies 0
