Community Helping Community
729
Beginner
ASyncOS 7.0 Citrix Connect
All,
Just wanted to post a heads up to everyone following the discovery and subsquent defect bug creation (ID# 72670 ) for Citrix connection issues following the upgrade to ASyncOS 7.0.  Below is the detailed description from our support engineer.
We examined the packet captures taken on the IronPort appliance when the Citrix portals work & when they fail and observed the following:
1) When the Citrix portals fail, the problem is that authentication between client & IronPort is failing. Looking at the capture, we see the below transaction resulting in failure:
CONNECT 216.220.93.69:443 HTTP/1.0
Host: 216.220.93.69:443
Accept:*/*
Connection: Keep-Alive
Proxy-Authorization: NTLM XXXXX
HTTP/1.0 407 Proxy Authentication Required
Mime-Version: 1.0
Date: Wed, 13 Oct 2010 14:10:02 EDT
Content-Type: text/html
Proxy-Authenticate: NTLM XXXXX
Connection: keep-alive
Content-Length: 0
2) Looking at a similar transaction (different domain) on the 6.3.3 version capture (working one), we see the below packets:
CONNECT sclin.myalegent.com:443 HTTP/1.0
Proxy-Connection: Keep-Alive
Content-Length: 0
Pragma: no-cache
Host: sclin.myalegent.com
Mime-Version: 1.0
Date: Wed, 13 Oct 2010 14:19:23 EDT
Proxy-Connection: keep-alive
Content-Length: 0
3) Comparing the capture information, we can see that the issue is being caused as the "Proxy-Connection: Keep-Alive" header is not being sent back by the IronPort appliance on the 7.0 version.
4) In the 7.0 build, the "Proxy-Connection" header was replaced by the "Connection" header per RFC requirement & interoperability problems seen with certain clients/applications (when "Proxy-Connection" header is used).
5) However, it looks like the Citrix client is unable to process the "Connection" header properly and requires the "Proxy-Connection" header instead
We have filed a defect ID# 72670 for this issue and our development team is working on releasing a fix for the behavior. The defect is being planned to be addressed in a 'HOT Patch' release and we will inform affected customers once the fix is released.
Everyone's tags (3)
Content for Community-Ad
FusionCharts will render here
