Bloomberg Traffic through Cisco WSA
We have Cisco WSA deployed as transparent proxy. There users who accesses Bloomberg which uses non-http UDP and TCP ports. The customer wants to send this traffic through WSA. Does the WSA handle this type of traffic?.
Shabeeb
5 Replies 5
No. Most of their traffic isn't http so putting it through the WSA just breaks it
amojarra
WSA is a web Proxy and supports HTTP/HTTPS and FTP for proxying.
If it uses any of above applications (HTTP/HTTPS/FTP) but deferent port number ( other than 80/443/21) WSA can handle them.
Long story short the Application layer is important in WSA.
Amirhossein Mojarrad
++++   If you find this answer helpful, please rate it as such  ++++
fw_mon
Hello Shabeeb,
Bloomberg support SOCKS v5, so it should work with WSA.
To configure it in the Bloomberg Connection Wizard go to Settings > Connect through a SOCKS Version 5 Proxy server.
Let us know how it worked
I tried to configure SOCKS proxy in Bloomberg and configured SOCKS policy in WSA. Eventhough I allowed the bllombeg ports and destinations in SOCKS policy it is not hitting the policy. I am getting the below error.
How can I allow bloomberg.net:8292?. In custom URL it is not accepting website:port syntax. Kindly advise.
fw_mon
Hello Shabeeb, check access log for the block reason. I wouldn't use web tracknig view for troubleshooting, it has some limitations, use logs directly instead.
