05-10-2021 10:29 PM
I would like to ask if there is a way to see when the management (gui) certificate is expiring.
From cli or gui
Is there a way to create an alert ?
Thanks and regards,
Konstantinos
05-11-2021 01:46 AM
For what product?
05-11-2021 01:47 AM
WSA
05-11-2021 02:14 AM
Easiest way is to just examine it in your browser toolbar when you go to the WSA.
05-11-2021 06:59 AM
05-12-2021 11:06 PM
Hello
Then sth is wrong, because I install it through CLI, but I do not see it in the gui
05-13-2021 01:30 AM
Did you commit after making the cli change?
05-13-2021 01:44 AM
Yes and I see the cert is renewed but I get this error
inside the cert
05-13-2021 12:26 PM
Key usage should include those fields. The Yellow ! in a triangle is normal and should not prevent the certificate from working.
05-13-2021 11:52 PM
Hello Marvin,
Good to know about the key usage.
The issue was with CSR was missing an extra field.
Konstantinos
