3642
WCCP not working fine.
I have a WSA connected directly to C6509. The scenario is Clients, single WSA and Internet access are all on different VLAN's.
In 6500 I have configured:
ip wccp version 2
ip wccp 90
In WSA is created a group WCCP 90.
But WCCP seems not working fine. The output in 6500 are:
6509-Impsat#sh ip wccp 90 detail
WCCP Client information:
WCCP Client ID: 127.0.0.1
Protocol Version: 2.0
State: NOT Usable (Initializing)
Redirection: L2
Packet Return: L2
Packets Redirected: 0
Connect Time: 00:00:09
Assignment: MASK
6509-Impsat#sh ip wccp 90 view
WCCP Routers Informed of:
-none-
WCCP Clients Visible:
10.1.200.1 -----> IP IronPort
WCCP Clients NOT Visible:
-none-
Still I don´t apply interface redirection in 6500.
What could be the problem?.
Regards and thanks.
Jaime
9 REPLIES 9
Hi Jaime,
My name is Tery and I am with Cisco IronPort Support Web team, I will be happy to help you out figure out why WCCP is NOT in a usable state.
First thing I notice is that WCCP is recognizing the WSA as a loop back address, did you added the redirect in statement?
Can you paste the WCCP configuration?
Tery
Here are the examples for WCCP in a 6500.
Example 1
ip wccp web-cache redirect-list 110 password umgov
interface Vlan110
ip address 10.8.86.254 255.255.255.0
ip wccp web-cache redirect out
access-list 110 deny   ip any 192.168.90.0 0.0.0.255
access-list 110 deny   ip 202.185.113.0 0.0.0.255 any
access-list 110 permit ip any any
The password above is optional.
Example 2
ip wccp web-cache redirect-list IRONPORT group-list 15
ip access-list extended IRONPORT
permit tcp 10.1.15.0 0.0.0.255 any eq www
access-list 15 permit 10.1.15.10
interface Vlan15
  ip wccp web-cache redirect in
Example 3:
This is all on a 6500 running IOS 12.2
Overview:
All traffic on VLAN 11, which is 172.22.11.0/24, is to be sent to Ironport to filter.
This example filters all traffic on that subnet, no exception.
!!! below turns on wccp with service ID of 90
ip wccp 90
!!! below is the VLAN interface of the VLAN/Subnet that we want to filter
interface Vlan11
  ip address 172.22.11.1 255.255.255.0
  ip wccp 90 redirect in
!!! below is the access-list that identifies traffic to be redirected
!this says anything to 192.168.0.0/16 will not be redirected
!this says anything on 172.22.11.0/24 will be redirected
deny tcp any 192.168.0.0 0.0.255.255
permit tcp 172.22.11.0 0.0.0.255 any eq www
!!! below says to redirect traffic based on the named ACL
ip wccp  90 redirect-list IRONPORT
The difference between example 1 and  example 2 is that example 1 redirects traffic on the interface to  Internet (redirect out) and example 2 redirects traffic on the interface  of the client network (redirect in).
The below link explains Cisco WCCP commands:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122sup/122csum/csum1/122csfun/fsf018.htm
Hope this helps!
Tery
Highlighted
Hi Jaime,
Yes I believe the redirect in statement is the only thing missing here.
Tery
Thanks Tery,
I´m going to test with redirection interface.
For example, I want apply redirection only one IP (10.10.10.2). The configuration in 6500 would be:
(config)#access-list IRONPORT extended permit ip host 10.10.10.2 any
(config)#ip wccp version 2
(config)#ip wccp 90 redirect-list IRONPORT
(config)#interface vlan 215
(config-if)#ip wccp 90 redirect in
It´s correct?
Thanks again,
Jaime.
Your missing this statement
permit tcp 10.10.10.0 0.0.0.255 any eq www < Are you re-directing just port 80 or all ports?
Tery
Hi Tery,
I want redirect por 80 and 443.
Jaime.
Hi Tery,
I have applied the following configuration in 6500:
permit tcp host 10.1.3.44 any eq www
ip wccp version 2
interface Vlan215
ip address 10.100.0.1 255.255.255.0
Now, WCCP is working fine:
        WCCP Client ID:          10.1.200.1
        State:                   Usable
        Redirection:             L2
        Packet Return:           L2
        Connect Time:          00:15:13
        Assignment:            MASK
But, traffic of IP 10.1.3.44 isn´t redirected to IronPort.
6509-Impsat#sh ip wccp interfaces counts
WCCP interface counts:
    Vlan215
        Output packets redirected
            Process: 0
            CEF:     0
        Input packets redirected
            Process: 0
            CEF:     0
I would appreciate your help.
Jaime.
Hi Tery,
The configuration in 6500 is:
ip wccp version 2
ip wccp 90
I am going to apply redirection to VLAN 215, but it´s still I have not done.
Thanks!
Jaime.
Beginner
Re: WCCP not working fine.
My name is Rajnish and i am also suffering with same problem.
have you got any solution for this?
if you have any idea then please assist me.
