Would recommend to request the Support Engineer to check the RAID battery again after you have replaced it, since they will need to check this from the backend logs (non-customer facing logs).
For WSA, you do not need to disable anything, you only need to gracefully shutdown the appliance before proceeding the replacement.
Handy Putra
