Bulk register devices to Cisco Webex
aman.kapuria
Level 4
Level 4
Hi Guys,
We are looking at registering around 500 devices (migration from VCS/TMS) to Cisco Spark/Webex. Is there a way to automate the device registration without having to go to each and every device and add the code? I have looked and can't seem relevant information in Cisco doco.
Vaijanath Sonvane
Hi Aman,
You will have to configure WebEx Places and Devices manually. The bulk provisioning feature is only available for User configuration. It is not available for WebEx Places and Devices at this time.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
@Vaijanath Sonvane
Is the bulk migration from on-promises registered VC endpoint to Webex Cloud available now?
@gerence Check out the cloud onboarding functionality: https://help.webex.com/nutc0dy/
This is a feature of the Device Connector tool (available for download from Control Hub): https://help.webex.com/383gbd/
Hope this helps!
Marc
dan.engelhardt
I have this same question but in addition would like to use a template for the devices so certain settings can be configured, similar to a config file in CUCM.
