CONNECT WEBEX WITH A H323 ENDPOINT
Good morning,
I need your help to connect my Webex room with my Sony ipela pcsx80 station (end-point), H323 protocol, that doesn't support SIP protocol.
The IP of my Sony ipela is  IP 93.187.29.13.
The station is registered on our gatekeeper and can be reached at 05771082@93.187.29.12. The station CAN be deregistered from our gatekeeper and can  work "stand alone".
1. End-point -> Webex
On the Sony ipela station in which format should I compose the connection request?
I tried 952444333@62.109.219.4 but it doesn't work.
2. Webex -> End-point
How can I connect the station directly from the webex environment?
Thank you so much!
Goswin Weemaes
@Consorzio Terrecablate , in the Webex invitation you should see the following:
Can you try to dial that IP address from your H323 endpoint and then enter the number of the meeting you want to join?
Response Signature
