HA with IRP
netanelda
Hey,
I installed CWMS 4, it supposed to be with HA and IRP.
I manage successfully to connect the Main IRP to the main system,
But when I try to add HA from the second system(when I choose "use this system for HA", and check the "use IRP", Manual deployment)
The connection test to the IRP failed, in the firewall there is only 64616 port.
What can be the problem? the first IRP is in the same subnet as the second one.
0 Replies 0
